Burr-Brown vs Cirrus Logic vs Analog Devices: What are the differences between these three DACs - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 22 Old 11-28-08, 12:48 PM Thread Starter
tonyvdb's Avatar
Tony
Right now there are three main companies developing DACs for Receivers and such.
Texes interments, Burr-Brown
Cirrus Logic
Analog Devices
With the recent switch from using the Bur-Brown DACs in the lower end Onkyo receivers to the Cirrus Logic DACs I wonder if this really makes an audible difference.
Pioneer and Denon have been using the Analog Devices DACs in some of there receivers
Yamaha and the higher end Onkyo's and Denon are Using Burr-Brown
And Marantz and the newer lower end Onkyo's are using the Cirrus Logic DACs
Home theater:
Living room system:
tonyvdb is offline
post #2 of 22 Old 11-29-08, 08:53 AM
HTS Senior Moderator
nova's Avatar
Mark
re: Burr-Brown vs Cirrus Logic vs Analog Devices: What are the differences between these three DACs
Good question,... to which I have no answer. For some unknown reason I have always assumed the BurrBrown DACs were the best
Mark
nova is offline
post #3 of 22 Old 12-01-08, 02:31 AM
drf
drf
DACs, like op amps, are only as good as the supporting circuitry. To the end user it doesn't really matter which dac is used, so long as the unit as a whole is properly designed. In other words a good chip that is poorly implemented will sound worse than a poor chip properly implemented. I would buy based on overall performance rather than what chips they use.
You are significantly more likely to hear a difference in the program algorithms and fx processing than you are dac performance.
my 2c
Dr F
drf is offline
post #4 of 22 Old 12-01-08, 11:24 AM Thread Starter
tonyvdb's Avatar
Tony
drf wrote: View Post
Thats a very good point, And one to seriously keep in mind when buying an new Receiver or PrePro.
Home theater:
Living room system:
tonyvdb is offline
post #5 of 22 Old 12-26-08, 11:01 AM
Re: Burr-Brown vs Cirrus Logic vs Analog Devices: What are the differences between these three DACs
Here are a few specs for various DACs:
Burr-Brown PCM1791 (SNR 113dB / THD 0.001%)
Burr-Brown PCM1796 (SNR 120dB / THD 0.0005%)
Burr-Brown PCM1792 (SNR 129dB / THD 0.0004%)
Cirrus Logic CS4398 (SNR 120dB / THD 0.0007%)
Analog Devices AD1955 (SNR 120dB / THD 0.0006%)
Wolfson Microelectronics WM8741 (SNR 128dB / THD 0.001%)
Sonnie is offline
post #6 of 22 Old 12-26-08, 12:04 PM
Banned!
In addition to chiming in with "DRF's comments sound spot on to me", I would add...
Well, those SNR and THD numbers might make a difference if you were really cranking the system (like, stadium levels), but I'd be curious to see study where at 85dB in your Home Theater someone was able to hear the difference. Even the worst spec'd of those DACs (SNR 113dB / THD 0.001%) still has great numbers, though as DRF said, it's only part of the equation.
eugovector is offline
post #7 of 22 Old 12-26-08, 12:13 PM
Bob
Send a message via AIM to bobgpsr
Used to be that Burr Brown and Analog Devices had the best reputations for quality performance and truly meeting their specs. Now it looks like Cirrus Logic and Wolfson have arrived, as far as specs go, for consumer audio playback.
bobgpsr is offline
post #8 of 22 Old 12-26-08, 01:24 PM
SteveCallas's Avatar
Steve
Nowadays there won't be an audible difference between DACs, circuitry, algorithms, or anything else unless the manufacturer has purposefully intended to achieve a non flat FR or the amp section is way underpowered. Look to power, inputs/outputs, and features rather than DACs or claimed sound quality.
SteveCallas is offline
post #9 of 22 Old 12-26-08, 02:09 PM
Looks like it has been covered. No difference unless something is broken or the difference is done on purpose. With the types of specifications DACs have humans would need more than golden ears to hear a difference!
avaserfi is offline
post #10 of 22 Old 12-29-08, 01:56 AM
thxgoon's Avatar
thxgoon
Sonnie wrote: View Post
Agreed with all said above. According to these specs we're talking about a ten-thousandth of a percent or .000000# difference between DACs. Hardly measurable let alone audible.
thxgoon is offline
dacs , differences
