How to "bass crawl" to place dual subs? - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 14 Old 03-19-19, 08:28 PM
HTS Moderator
Reviewer
theJman's Avatar
Jim
Re: How to "bass crawl" to place dual subs?
Philnick wrote: View Post
It just occurred to me that playing the downward-firing - and thus omnidirectional - sub in the main listening position would allow me to crawl for the loudest bass in both locations (in the front left and rear right parts of the room), rather than dragging each sub there plugged into a different jack.
Once I decide on the two locations, then I'd wire up a sub in each location.
Does this make sense?
I'm not quite sure I understand what you're saying but there is one point to clarify; bass is omnidirectional, irrespective of driver orientation. Front firing, down firing, side firing, it all pretty much does the same thing. There are some advantages/disadvantages to each alignment, but bass waves will propagate in all directions from every one of them.
-Jim
theJman is offline
post #12 of 14 Old 03-19-19, 08:34 PM
HTS Moderator
Reviewer
theJman's Avatar
Jim
Thanks! It'll be a few months until I get the room rebuilt, but you've given me a lot to chew on.
BTW, I'm wiring the in-wall line-level runs from the AVR to the wall jacks for the subs using coax, with coax-to-RCA adapters at either end, and RCA cables terminated with whatever connector is needed at the AVR and each sub.
I'm assuming that coax will make decent in-wall line-level cables for the sub signals.
Coax typically has good shielding so that should work fine. Even so, I would try to keep the coax runs away from the electric cabling.
-Jim
theJman is offline
post #13 of 14 Old 03-23-19, 01:44 PM
needspeed52's Avatar
bundini
perceval wrote: View Post
Best way is to use the REW software.
You can have REW play a pink noise, install the mic at your listening position and use the RTA settings mentioned in the post.
Then you can view in real time the changes happening when you move either of the subs.
PS. if you get cancellations that seem almost impossible to fix, try flipping the phase on one of the subs.
Follow directions from here:
https://www.hometheatershack.com/for...ml#post1612934
Correct me if I'm wrong, would it not be easier and just as accurate to place sub(s) at MLP and move mic around the room with the RTA settings and observe the response for best location(s)?
needspeed52 is offline
post #14 of 14 Old 04-22-19, 05:14 PM
blekenbleu
My guess is that your original second proposal would be most expedient:
* Place one subwoofer in the primary listening position, playing pink noise
* crawl for "best" bass (either by ear or ideally real-time spectral display of calibrated mic)
* place and play subwoofer pink noise at "best" bass position, along with subwoofer at listening position.
* crawl for optimal second bass position with both subs playing,
accounting for constructive and destructive interferences.
blekenbleu is offline
bass crawl , dual , place , subs
