Is this Crazy? - Use high mounted rears for IIz heights - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 3 Old 08-30-12, 01:43 PM Thread Starter
Mark Anderson
Hi All
Just got a new Denon 4311CI. Tried some front wides yesterday: amazing. Can't believe the difference.
Keen to try front heights BUT no where to put them. I came up with a crazy idea. i have two rear channel speakers mounted above my window at rear of room. As there's virtually no 7.1 content out there and they seem to add little, i wondered if I could use them as "front" height speakers for IIz.
As crazy as that sounds, as long as the delay is set correctly wouldn't I get the same affect? I keep hearing about how sound bars, and lab test, etc. can produce 3D sound, so why wouldn't this work? Obviously, they are in the wrong physical location, but with the correct delay and magic of Audessy I would hear the sound from these before my front wides and surrounds, and it would be above me. Would it matter that it's coming from the wrong direction?
Gonna give it a shot at the weekend. Wondered if anyone would care to predict the results?
Regards
Mark
mark_anderson_us is offline
post #2 of 3 Old 08-30-12, 03:00 PM
New Member
Re: Is this Crazy? - Use high mounted rears for IIz heights
I mean you can do that, however, the sound will still come from the rear rather than the front, if I understood your thoughts correctly - converting the rears into heights and then try to fix it with the delay settings.
The delay settings only helps you to put the speakers more away from you but not in front of you.
However, give it a try. I would be interested to read about the outcome.
Good luck
m
mabuse04 is offline
post #3 of 3 Old 08-30-12, 04:08 PM
robbo266317's Avatar
bigbadbill
You will probably find it brings the front sounds into the centre of the room.
Set your receiver to all cannels stereo or mono to see what I mean.
Silence is golden but duct tape is silver.
DIY completed:
robbo266317 is offline
crazy , heights , high , iiz , mounted , rears
