Oppo 203 - Page 3 - Home Theater Forum and Systems - HomeTheaterShack.com
 4Likes
post #21 of 27 Old 03-03-17, 09:10 AM
ConnecTED's Avatar
Re: Oppo 203
Quick Update to the Digital Error test I performed with OPPO UDP-203 and posted the results earlier here, I have checked the HDMI Input also for digital errors using an YCbCr 4:4:4 / 4:2:2 8bit HDMI Input signal and I found it bit-perfect also!
Software: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
Video Processors: eeColor 3D LUT Box, Darbee DVP-5000 - Pattern Generator: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1Display PRO, Chroma 5 PRO
ConnecTED is offline
post #22 of 27 Old 03-03-17, 12:36 PM
NorthSky's Avatar
Re: Oppo 203
That's excellent news Ted. Did you also check for audio/video sync? ...From various sources.
~Bob / Life, Love & the Blues
NorthSky is offline
post #23 of 27 Old 03-03-17, 01:13 PM
ConnecTED's Avatar
Re: Oppo 203
NorthSky wrote: View Post
Hi, sync is related with HDMI input lag (internal display colorspace conversions/processing), I can't test this because it will different per setup.
post #24 of 27 Old 03-03-17, 11:55 PM
NorthSky's Avatar
Re: Oppo 203
Ah, it's all right.
http://www.hdfever.fr/2017/01/01/pretest-oppo-udp203eu/
NorthSky is offline
post #25 of 27 Old 03-24-17, 04:20 PM
NorthSky's Avatar
Re: Oppo 203
I looked @ the most recent Oppo 203 thread and this is it.
Release date: March 24, 2017
Category: Latest Public Beta Test Release
Main Version: UDP20X-41-0317B
Loader Version: TF0030
MCU Version: MCU203-01-1118
Release Notes:
1. Added the Dolby Digital and DTS options under the S/PDIF Output setting in Audio Output Setup, which allows the player to re-encode different audio formats into the Dolby Digital or DTS audio format for the S/PDIF output.
2. Improved the output accuracy when using the RGB PC Level color space.
3. Resolved a frame dropping issue when using cable or satellite boxes through the HDMI In.
4. Improved A/V sync when using the HDMI In.
5. Resolved an issue where the Full zoom mode would not fill the screen when playing 4:3 content.
6. Improved stability when accessing SMB servers.
7. Resolved an issue where ejecting the disc tray could lock up the player.
8. Improved compatibility with Optoma 4K projectors.
General disc compatibility improvements based on recent and upcoming UHD Blu-ray releases as well as user-submitted disc samples.
NorthSky is offline
post #26 of 27 Old 03-25-17, 03:18 PM
ellisr63's Avatar
Ron
Re: Oppo 203
Thanks for posting that up... I am still on the older firmware.
Sent from my SM-T550 using Tapatalk
My Home Living room Theater
Samsung 65" FP, Yamaha CX-A5100, Xilica XP4080, (4) Klipsch RP160MS, (4) JBL 8340As, (2) Yamaha P2500s amps, PS3, XBox One, (1) Asus mini pc, (2) Furman Power Conditioners, Darbee Darcet, and a Project RPM 1.5 Carbon turntable..
ellisr63 is online now
post #27 of 27 Old 03-26-17, 04:33 PM
NorthSky's Avatar
Re: Oppo 203
Ron, from your Oppo 203 are you using both HDMI outputs or only the main one?
Also, how is your overall experience so far with Blu-rays from your 203's operational side?
And last, your Yamaha pre/pro; do you think it can carry Dolby Vision from its HDMI outputs?
One more ...4K is the new BR format, and slowly it's getting HDR better, and Dolby Vision is just around the corner, and Dolby Atmos is getting more and more exclusive to 4K Blu-ray discs from many studios now...the big push plus the let go of 3D immersive audio support for the immersive video BR discs...like 'Fantastic Beasts and Where to Find Them' from Warner Bros. It is alarming and disconcerting but c'est la vie; 3D good bye, and 4K we all need to buy. We have no choice, they don't make low res TVs anymore (1080p only), or quasi not. How long till you convert the rest of your home theater rig to the next higher Dolby Vision level?
Cheers,
NorthSky is offline
203 , oppo
