Internet speed problems - Page 4 - Home Theater Forum and Systems - HomeTheaterShack.com
 13Likes
post #31 of 38 Old 12-17-16, 10:57 AM Thread Starter
ellisr63's Avatar
Ron
Re: Internet speed problems
I am upgrading my Netgear switches to Cisco Business class switches. I have been running a Cisco SG200-26 in our HT for several years now, and since I am running out of ports, I decided to move up to 18-20 port switches. I picked up a SG200-18 for our LR, and a SG300 to run next to our Netgear R7000 router (all 3 pieces were less than the first SG200 was). The guy that I bought the SG300 from gave me a 890 series router (labeled 891)...not sure if it will be easily configured or not, but if i keep it I hope it is better than the R7000 is.
http://www.cisco.com/c/en/us/product...78-519930.html
My Home Living room Theater
Samsung 65" FP, Yamaha CX-A5100, Xilica XP4080, (4) Klipsch RP160MS, (4) JBL 8340As, PS3, XBox One, (1) Asus mini pc, (2) Furman Power Conditioners, Darbee Darcet, and a Project RPM 1.5 Carbon turntable..
ellisr63 is offline
post #32 of 38 Old 12-19-16, 06:44 PM Thread Starter
ellisr63's Avatar
Ron
Today i spent several hours updating the firmware of my SG200-26 switch. I learned that Cisco requires you to do every update in order to do the next update, and that they changed the boot files on a few of them too, which meant I had to learn how to update that with TFTPD64 for the boot files. This last part took me the longest to figure out exactly what had to be done to do this every time. Once I had that figured out it went pretty smoothly, and fast...other than having to reboot after each firmware update, and boot update. I don't know what they did in the updates, but after doing a couple of them the Switch seemed to boot faster than it had been previously.
ellisr63 is offline
post #33 of 38 Old 12-19-16, 07:03 PM
HTS Moderator
Reviewer
theJman's Avatar
Jim
Maybe it got tired of all the reboots and simply decided to expedite the process. Glad it worked out in the end - I know it was quite the journey.
ellisr63 likes this.
-Jim
theJman is offline
post #34 of 38 Old 12-19-16, 07:09 PM Thread Starter
ellisr63's Avatar
Ron
theJman wrote: View Post
I have 2 more switches arriving tonight... I will be trying to get the firmware up to date tomorrow on those, and then get them into the system too. I was reading that I should arrange all my IP addresses to be in order, limit the IP addresses to the number of devices (so if i have 10 devices I would have only 10 IP addresses available...instead of hundreds), and use their MAC addresses too. Yesterday i found out that when you do a Guest account you can do it as a Virtual port, and restrict the usage to only the internet so no one has access to your Network. That is a nice feature IMO. It is going to take me a while to get all the IP addresses reassigned as static and in small groups. I wonder if by doing it this way if it will speed up my LAN...
ellisr63 is offline
post #35 of 38 Old 12-19-16, 07:35 PM
HTS Moderator
Reviewer
theJman's Avatar
Jim
I seriously doubt it will be any faster. Once a route is established it will be kept in the ARP cache, and from then on communications between devices will be port-to-port directly (at least until you reboot the switch or manually clear the cache). If you had a /20 or larger address space and ran it as one flat network - without subnets - there might be some benefit to keeping things sequential, but with the speed of most switches today I doubt you would notice a benefit in your situation.
-Jim
theJman is offline
post #36 of 38 Old 12-19-16, 08:30 PM Thread Starter
ellisr63's Avatar
Ron
We have close to 40 devices spread over 3 switches with switches being 18, 20, and 26 ports running to our Netgear R7000 router with DD-WRT firmware.
ellisr63 is offline
post #37 of 38 Old 12-20-16, 01:47 PM Thread Starter
ellisr63's Avatar
Ron
Today is going much better... I almost have all the firmware completed on the SG200-18, and next will be the SG300-20. I still have to decide if i am going to keep the Cisco 890 Router or sell it, and keep using the R7000 WIFI Router.
ellisr63 is offline
post #38 of 38 Old 05-05-19, 03:54 PM
deathshad0w's Avatar
I've found a list of good programs that may help you out with the speed problems, check it out.
deathshad0w is offline
internet , problems , speed
