Another 10" CSS build - Page 6 - Home Theater Forum and Systems - HomeTheaterShack.com
post #51 of 133 Old 03-11-09, 08:58 PM Thread Starter
Rodny Alvarez's Avatar
Rodny
Re: another css 10" build
jmuir wrote: View Post
Look'n good Rodny. Are you going to be able to incorporate the 3/4" plexiglass into this sub? It would be pretty neat to use if for the side to show off the work you did on the port. It would also make a good visual tool to show people how the inside of a sub looked. Add your neon and that would be one funky sub.
John
Not on this one, we got really busy at work so no extra time to do side work, maybe next box!!
Thanks!
Interesting slot design. Is there a reason you didn't use the bottom/side walls for the port? Or at least the use the bottom to save some box volume.
It was easier for me to build the port this way!
Ok!!
stayed a little late tonight and got some more work done, here is the progress.........
Rodny Alvarez is offline
post #52 of 133 Old 03-12-09, 01:14 AM
robseyes's Avatar
Bob
I hope you don't plan on covering up the side of that box without some sort of plexiglass to show off your work. That looks nicer inside than mine does on the outside! Now excuse me while I go kick my boxes....
robseyes is offline
post #53 of 133 Old 03-12-09, 05:47 AM
Owen Bartley's Avatar
OJ
Looking great Rodny! I really like how the slot port turned out, how big is that roundover?
- OJ -
Owen Bartley is online now
post #54 of 133 Old 03-12-09, 06:39 AM Thread Starter
Rodny
Thanks Owen!!!!
The inside 3/4" and the out side 1 1/4"!
Thanks!
post #55 of 133 Old 03-12-09, 12:49 PM
Ricci's Avatar
Josh
That slot port looks like it was a lot of work. Turned out well though.
Ricci is offline
post #56 of 133 Old 03-12-09, 08:32 PM Thread Starter
Rodny
Ricci wrote: View Post
Its not that bad really!!
Put the sub together because I wanted to hear it, there is another piece of 1/2" going in the back, the amp will be flush on that piece, this thing its HEAVY!! you can see on the last pic 82lbs, I dint think it was going to be that heavy.
I'm going to play it some more this weekend and do some measurements.
I did a 3/4" round over but I was thinking of using the 1 1/4", what you guys think? do it or live it like that?
So far a very impressive little thing!!!
post #57 of 133 Old 03-12-09, 10:36 PM
Kyle
perfect, now just need to make one for a 12"
hows she sound? makes you want to get rid of the 15s right?
oh yea...show off
bamaboy is offline
post #58 of 133 Old 03-12-09, 10:46 PM
Kyle... he must not be getting any work done at the shop... working on this thing all day long.
Sonnie is offline
post #59 of 133 Old 03-13-09, 06:38 AM
OJ
Looks good Rodny!! I think I'd leave the roundover as-is... a wider one might look weird, but then again if you're painting it candy red and doing it as a fun project, it might work still.
Looks like you tried it in the front and in the back? What did you think? Pretty great for a 10-incher, isn't it!?
- OJ -
post #60 of 133 Old 03-13-09, 07:07 AM Thread Starter
Rodny
Sonnie wrote: View Post
Yeah right!!
Lets see...........my lunch hour and staying late after work!
I placed the sub on the front and it sounded good but you can tell where the sub was, move it to the back of the room and wow! it made a big difference and you couldn't tell where the sub was, called Kevin and told him to sit down and tell me where the sub was and he said it was the front subs playing, we listened to Sarah McLachlan dvd.
I need to set the gain on sub and move it around the room and see where it will sound better, I did try it downstairs and with music (cd) it was ok , played a movie and it fill the room pretty good, nothing crazy loud but good enough, this is perfect for a small room,my living room is pretty big and is open to other rooms in the house, I'm pretty impress with this thing, now the fun part begins......paint...sanding.....paint.......sanding........,
10" , build
