V2 Speaker upgrade options - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 2 Old 11-27-13, 09:11 PM Thread Starter
RAW
Al
The new V series speaker kits from CSS are available with many options for each speaker kit
V2 speaker kit which uses a pair of VWR driver in a MTM configuration in a mid sized monitor.
For those not listed on the CSS site please contact for pricing
CSS V2 speaker kit acoustic foam damper pads
CSS V2 speaker kit Mill resistor upgrade
CSS V2 speaker kit Mills resistor upgrade acoustic foam damper pads
CSS V2 speaker kit Obbligato capacitors with Mills resistors 16g teflon wire Acoustic foam,damper pads
CSS V2 speaker kit Obbligato capacitors with Dueland resistors 16g teflon wire Acoustic foam,damper pads
CSS V2 speaker kit Obbligato capacitors with Mills resistors 14g DHLabs wire Acoustic foam,damper pads
CSS V2 speaker kit Obbligato capacitors with Dueland resistors 14g DHLabs wire Acoustic foam,damper pads
CSS V2 speaker kit Mundorf EVO capacitors with Mills resistors 16g teflon wire
CSS V2 speaker kit Mundorf EVO capacitors with Dueland resistors 16g teflon wire
CSS V2 speaker kit Mundorf EVO capacitors with Dueland resistors 16g teflon wire Acoustic foam,damper pads
CSS V2 speaker kit Mundorf EVO capacitors with Mills resistors 14g DHLabs wire
CSS V2 speaker kit Mundorf EVO capacitors with Dueland resistors 14g DHLabs wire
CSS V2 speaker kit Mundorf EVO capacitors with Dueland resistors 14g DHLabs wire Acoustic foam,damper pads
RAW is offline
post #2 of 2 Old 12-06-13, 06:35 PM
CSS Owner
Bob
Re: V2 Speaker upgrade options
More, so much more! Thanks Al.
Looking forward to quoting any of these as there is a need.
Bob
Creative Sound is offline
options , speaker , upgrade , v2
