Any interest in a car audio build with a pair of SDX10's - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 7 Old 04-07-14, 05:41 PM Thread Starter
tim
I know this is a HT forum, but i am ordering a pair of SDX 10's and plan on building a ported box for them. I am thinking from what i have read so far that i will build 2 separate boxes, 1.1 cu ft each, and tuned to 27hz.
Power will be 500 watts total, and it is a pure sound quality build. I will be able to EQ the sound using a HelixDSP that allows for RTA, Time alignment ( not critical here), and phase adjustment.
How does this sound so far? Problems i see will be how to address the port. 3" or 4" and how will it all fit inside the box.
tundraSQ is offline
post #2 of 7 Old 04-08-14, 02:18 PM
Mike P.'s Avatar
Mike
Re: Any interest in a car audio build with a pair of SDX10's
You should keep the air speed under 26 ms peak if using a 4 inch flared port
We're all in this together!
Mike P. is offline
post #3 of 7 Old 04-10-14, 07:40 AM
Mike P.'s Avatar
Mike
A 4" port is going to be hard to do, it would need to be 40" long. A PR might be an option if you want to keep the box size small.
Mike P. is offline
post #4 of 7 Old 04-10-14, 02:10 PM
RAW
Al
How about a slot port Mike.
RAW is offline
post #5 of 7 Old 04-10-14, 03:48 PM
Mike P.'s Avatar
Mike
That's possible. If the box is 10.5" wide internal then a 1" high by 32" long slot port would work.
Mike P. is offline
post #6 of 7 Old 04-10-14, 03:53 PM
RAW
Al
Mike what is the speed with the slot
RAW is offline
post #7 of 7 Old 04-10-14, 04:23 PM
Mike P.'s Avatar
Mike
With 250 watts and HPF at 20 hz it's under 19 m/s peak.
Mike P. is offline
audio , build , car , interest , pair , sdx10
