-   Creative Sound Solutions (https://www.hometheatershack.com/forums/creative-sound-solutions/)
-   -   Dual CSS SDX12 Ported/Sealed (https://www.hometheatershack.com/forums/creative-sound-solutions/68892-dual-css-sdx12-ported-sealed.html)
Vin Vendel 07-31-13 05:34 PM
Hi!
The Promo SDX12 kit is ordered and the computer has run hot doing some Solidworks schematics but finally I can see the finished cabinets.
Letīs get to work!
Itīs going to be 85liter cabinets, after installing bracing, vents and driver Solidworks calculates the internal volume left and Iīm as close as possible to my targeted 75liters maybe 0.5liter less or more because all details in the driver are not removed in the basket.
Qtc: 0,530
Iīm using Inuke 6000dsp to power these beasts!
Subwoofers tuned to 23hz with three 70mm ports
Port airspeed kept below 30m/s with 20hz butterworth 2nd order highpass and very safe Xmax with 800rms input. Leaves some headroom for more PEQ :T
One port sealed gives a 19Hz tune and 100dB output @16hz
Two ports sealed gives a 13hz tune no gain there because of the 20hz EQ limitation in the inuke.
Iīm going to have a replaceable portplate so the subs can also run as true sealed.
Vin Vendel 07-31-13 05:36 PM
Re: Dual CSS SDX12 Ported/Sealed
PassingInterest 07-31-13 06:16 PM
Great job with the Sketchup. How long did it take to do all that? These should look pretty fantastic.
And does that generate a cut list or parts list?
Vin Vendel 08-01-13 05:30 AM
Thanks! Did not count the hours but at least one very long day.
Itīs done with Solidworks the program can make PDF outprints from every angel and part sadly that doesnīt help me very much because I still haft to sketch all pieces part by part and then make an assembly with them. The CNC machince is not the newest model and can only take 2D prints so I need to remove fillets as they are done afterwards and I also convert from solidworks filesystem to DWG.
Vin Vendel 08-01-13 05:33 AM
Iīm i little bit concerned about the SDX12 thiel parameters they donīt sum up in WinISD to match the numbers on the paper as many drivers do.
QTS and QES are not accurate I guess they are but I canīt manage to get it right.
BD55 08-01-13 08:32 AM
Tough to beat pro modelling software! About a million times more powerful than Sketchup, but I'm hoping they continue to add features common to CAD systems like Solidworks or NX.
I look forward to seeing how your build progresses!
Vin Vendel 08-02-13 05:56 PM
I really need a new computer my 7year old laptop takes a big amount of time to process pictures like this looks nice but some details disapered.
http://www.minhembio.com/bilder/hq/?pic_id=446271.jpg
Vin Vendel 08-08-13 02:31 PM
Vin Vendel 08-15-13 01:07 PM
MrMayhem 08-21-13 04:28 AM
Looks very nice, that driver.
I will follow this thread!
