Sub box build tips and tricks - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 9 Old 02-11-15, 10:28 AM Thread Starter
Ok guys doing a basic 4 cube box for a SI HT18 and want to see what everyone does for tips and tricks when building their boxes. So let me start of with, I like to use fiberglass resin on the inside of the box at the joints for a 100% seal and joint re-enforcement.
What do you guys do?
etroze86 is offline
post #2 of 9 Old 02-11-15, 10:42 AM
Steeve B.
Ideally I cut, screw and glue the top, side and bottom together. I usually cut my top and bottom slightly wider and glue/screw them over the side. I then use a router with a flush trim bit to make them perfectly flush. I do the same for the rear panel and the baffle. I brace a lot and use some silicone or other stuff similar to seal it. Wait a good 24-48 hour before installing the driver so the silicone fune don't attack the driver glue.
I adjust my saw table once and do all my same width cut to make sure they are all identical. Using a circular saw home made "track saw style guide" and a speed square I cut my lenght.
If you don't have a Jasper jig for circle just buy a piece of Polycarbonate from your local hardware store cutting center and make one out of it. Perfect circle every time.
Steeve-O is offline
post #3 of 9 Old 02-11-15, 11:03 AM
Wayne Myers
Re: Sub box build tips and tricks
Not a speaker builder guy here, but have worked a lot with resins. Some heat - heat lamp? - helps it cure faster AND STRONGER, more complex molecular intertwining or something like that.
AudiocRaver is offline
post #4 of 9 Old 02-11-15, 11:08 AM Thread Starter
That's interesting I've heard it didn't help to apply heat to resin.
etroze86 is offline
post #5 of 9 Old 02-11-15, 02:05 PM
Wayne Myers
Again, I do not claim to be an expert here, but I did study a bit about epoxy and resins in general for a project a few years back and read several places that it can make a significant difference. Conversely, curing time and strength can be lengthened and degraded in a cold environment.
They are pretty strong either way, it might not make a meaningful difference for this application. Just throwing the idea out there.
post #6 of 9 Old 02-11-15, 02:08 PM Thread Starter
Oh defiantly not trying to negate what you are saying and I believe you as you have studied it way more than I lol.
Ok throwing this out, binding posts or speaker wire cups? In the car audio world you see a ton of people fitting with cups instead of using binding posts. So what is everyone's thoughts there.
etroze86 is offline
post #7 of 9 Old 02-17-15, 05:03 PM
I like to use fiberglass for installs in tight spaces in cars. It really lets you use the most of your airspace and tuck it in tight. It's a huge pain in the neck compared to a simple mdf box, but it looks so much better and saves a ton of cargo space.
bigsausagepizza is offline
post #8 of 9 Old 02-20-15, 12:48 PM Thread Starter
So what is everyone's thought about enclosure finishing? I might be doing a carbon fiber vinyl wrap for a coworker, but he also brought up using a veneer. Do veneers wrap over roundovers as well as vinyl does?
etroze86 is offline
post #9 of 9 Old 03-08-15, 08:28 PM
Verse-n-Chorus's Avatar
For enclosure constructioin , I always use a glue & screw approach;
the glue also acts as a first line of defence in sealing.
To seal the insides , I have used automotive 'sound deadening',
and concentrated the spray on the inner corner joints.
Finally , 'T' nuts make sure that you speaker mounting hole never get
stripped - out.
Then cover the box with various materials depending on usage.
I have rolled on DuraLiner for DJ cabinets because it is tough.
Some wood vaneers have a hot - melt glue backing that covers screws
good; They don't want to bend around too sharp , or small radius.
From my experience making DJ cabinets , I have become a big fan
of Peavey's binding cups -- used with either Neutrik or
Switchcraft connectors ; also G&H make nice 1/4 inch speaker cable
connectors -- the black housing with gold plated connections are
very nice.
Verse-n-Chorus is offline
box , build , tips , tricks
