DIY wall mounts - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 13 Old 05-16-16, 08:06 AM Thread Starter
DIY wall mounts
I was looking online for some speaker mounts that would fit my needs, and I was disappointed at the options. I want something that can angle down to 45 degrees, be attached with screws to the back of a speaker with no existing mounting option, and is as invisible as possible. This is what I came up with. I implemented the idea of just bending a sheet of metal instead of relying on the tightening of a screw to cause sufficient friction to stop vertical movements. The piece on the wall is 2" x 2" x 1/8" angle iron fastened into a stud. The other piece is a 5" x 1.5" x .06" bent to the proper angle. I am just posting this as an easy/cheap idea for others. Now I just need to put up some crown molding to cover the cable and terrible drywall job. Let me know what you think.
clint357 is offline
post #2 of 13 Old 05-16-16, 05:40 PM
Nick
Re: DIY wall mounts
Looks great!,
nheintz is offline
post #3 of 13 Old 05-16-16, 09:04 PM
ellisr63's Avatar
Ron
Re: DIY wall mounts
Looks great!
My Home Living room Theater
Samsung 65" FP, Yamaha CX-A5100, Xilica XP4080, (4) Klipsch RP160MS, (4) JBL 8340As, (2) Yamaha P2500s amps, PS3, XBox One, (1) Asus mini pc, (2) Furman Power Conditioners, Darbee Darcet, and a Project RPM 1.5 Carbon turntable..
ellisr63 is offline
post #4 of 13 Old 05-16-16, 09:14 PM
Re: DIY wall mounts
How much does the speaker weight? I would be worried about having all the torque being applied to the bend in the 16ga steel bracket. The 2x2 angle should be beefy enough for almost any box... maybe a piece of cable or chain anchored to the 2x2 angle, and attached to the top end of the cabinet? That would split the load between the bent piece and the wall, and significantly reduce the possibility that the bracket will drift over time.
I suppose if the boxes are light enough it might be fine, but I tend to overengineer things... mostly because I have to get things approved by an engineer at work and he's crotchety and paranoid.
DqMcClain is offline
post #5 of 13 Old 05-16-16, 09:31 PM
ellisr63's Avatar
Ron
Re: DIY wall mounts
DqMcClain wrote: View Post
It appears to be close enough to the ceiling that a 2nd bracket could be made to mount to the ceiling...in my area Northern Cal (earthquakes) it would be better to have top, and bottom, but I really have no room to talk living where I do with 2 300lb doors between me and the outside.
ellisr63 is offline
post #6 of 13 Old 05-17-16, 04:42 AM Thread Starter
Re: DIY wall mounts
The steel has no problem with these speakers. This setup would probably be good for up to a 10lb speaker. Depending on the angle you are looking for, you could mount the strip closer to the top of the speaker so it would be closer to its balance point and allow it to hold a lot more weight. If you had a larger speaker you could just use a wider strip. The good thing is that if it fails, the bracket will just bend over but the speaker would not fall. Metal also does not "creep" like plastic, meaning that if it is holding right now then it will hold forever. It will not slowly succumb to gravity.
clint357 is offline
post #7 of 13 Old 05-17-16, 08:14 PM
Re: DIY wall mounts
clint357 wrote: View Post
True, metal doesn't tend to creep... under a completely static load. But If the load becomes spontaneously dynamic (cabinet vibration, slamming doors, earthquakes, really excited cats, etc) and the dynamic load applies force that exceeds the elastic deformation rating of the material and falls within the plastic deformation rating, then it can fail. The down-side to experiencing plastic deformation (plastic deformation causes permanent alteration to the shape for the structure, whereas elastic deformation allows the structure to return to it's original shape after the force is removed) in metals is that failure is both rapid and imminent due to material fatigue and alterations to force vectors involved.
Considering you said ..."up to a 10lb speaker" I assume the speakers you actually hung are considerably lighter than that. If that's the case then I have a hard time imagining one of those boxes shock-loading your mount so severely that it will break, short of a tornado or massive earthquake. And then you'll have other things to worry about.
So, I guess I have to say I like them. Nicely done. I may steel (he he) the design myself some day.
post #8 of 13 Old 05-18-16, 08:05 AM Thread Starter
Re: DIY wall mounts
I would be quite surprised (more impressed) if the vibrations were enough to work harden the metal and cause failure the next time I adjust the angle. I would be interested to see how many times you could bend that piece before failure, but I suspect that most people do not adjust their speaker angles that much.
clint357 is offline
post #9 of 13 Old 05-18-16, 11:10 AM
ellisr63's Avatar
Ron
Re: DIY wall mounts
You might want to check once in a while to make sure the screws haven't backed out any...other than that you are most likely fine with under 10lb speakers. Mins are 19lbs each.
ellisr63 is offline
post #10 of 13 Old 05-20-16, 06:48 PM
Re: DIY wall mounts
Yeah, with boxes that small and at reasonable levels, vibration-induced work hardening is a pretty tough sell. But when I'm at work, I have to plan for ridiculous situations... like the stripper throwing the piano player under a couch, and the piano player retaliating by hitting the stripper with the whips*
*That exact thing actually happened the other night.
diy , mount , mounts , wall
