repairing tiny tear in sub-woofer surrounds? - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 8 Old 08-09-13, 08:48 PM Thread Starter
Kyle
My old KLH sub-woofer has a tiny whole in the rubber surrounds, I am not sure what to use or were to find cheap stuff to repair it.
very small drill bit sized whole. on rubber surrounds
thanks~!
kingnoob is offline
post #2 of 8 Old 08-09-13, 11:12 PM
Plain ole user
lcaillo's Avatar
Tech Guru
Re: repairing tiny tear in sub-woofer surrounds?
How small is a "very small drill bit sized" hole? 1mm?
lcaillo is offline
post #3 of 8 Old 08-09-13, 11:58 PM Thread Starter
Kyle
Yes about 1mm Perhaps small enough that the surrounds will not need replaced.
kingnoob is offline
post #4 of 8 Old 08-10-13, 05:55 AM
Plain ole user
lcaillo's Avatar
Tech Guru
A dab of rubber cement?
lcaillo is offline
post #5 of 8 Old 08-10-13, 01:12 PM
tcarcio's Avatar
TC
I used some clear silicone on a small tear in one of my subs, I put a small amount on each side of the surround and it worked great.
tcarcio is offline
post #6 of 8 Old 08-10-13, 03:45 PM
dictator's Avatar
You need something that would be able withstand the movement of the cone. Amazing goop works perfect it's very popular for fixes like this in the car audio world. Pick some up at a automotive store for 5 or so bucks.
You can dab some on the front of the cone or behind or do both.
dictator is offline
post #7 of 8 Old 08-12-13, 01:25 PM Thread Starter
Kyle
Talking Re: repairing tiny tear in sub-woofer surrounds?
dictator wrote: View Post
amazing GOOP contact Adhesive??
says its good for plastic , metal,Polycarbinate and other car materials is the correct stuff. I would not want to put the wrong stuff on.
If it works on plastic it should work good on Rubber surrounds correct?
Price $5.99 so its cheap.
thanks!
Kingnoob
kingnoob is offline
post #8 of 8 Old 08-18-13, 09:49 PM Thread Starter
Kyle
So Amazing goop has worked very well, It seems to have repaired this sub-woofer hole. It is probably also good for repairing other various stuff.
General repairs are probably what its good for .
kingnoob is offline
repairing , subwoofer , surrounds , tear , tiny
