-   DIY Repair and Maintenance (https://www.hometheatershack.com/forums/diy-repair-maintenance/)
-   -   Speaker popping during explosions (https://www.hometheatershack.com/forums/diy-repair-maintenance/159802-speaker-popping-during-explosions.html)
Apollomeo 11-16-16 12:10 PM
I need some assistance figuring out why my front mains pop during BluRay playback. I have a Sherwood Newcastle R972 and Infinity OVTR 1 as my mains. Does not happen any other time except during explosions. Any assistance would be appreciated. Thank you.
ellisr63 11-16-16 01:02 PM
Re: Speaker popping during explosions
How loud are you listening to it? If you turn the volume down does it still pop on explosions?
Apollomeo 11-16-16 01:10 PM
I have the volume set low and even if I set it to where I can barely hear center channel, they still pop. You may not be familiar, but these speakers have powered subs.
ellisr63 11-16-16 01:14 PM
Apollomeo wrote: (Post 1520322)
How is the gain set on the subs...wondering if they might be meant for a smaller situation then you have. Are these pops like when you power up a sub after a power outage?
Apollomeo 11-16-16 01:40 PM
I have the gain turned all the way to 0, which is as low as I can get on the sub amps. These pops are much stronger and louder than a power up.
Apollomeo 11-16-16 03:26 PM
So, I found an adjustment on my AMP for LFE (low frequency effects) where I found adjustments to reduce levels on different modes like DTS and DTS ES MAster Audio, etc.. Problem solved.
Thanks for your responses.
Andre 11-17-16 09:38 AM
You've probably done it already but I would check the speaker cables and also try swapping them out to see if the popping goes away.
opell 03-05-17 08:59 AM
I agree it has something to do with the volume and troubleshooting it using the same speaker will allow you to determine what is really the defect.
