-   DIY Repair and Maintenance (https://www.hometheatershack.com/forums/diy-repair-maintenance/)
-   -   Dayton Audio SA230 stuck in standby mode (https://www.hometheatershack.com/forums/diy-repair-maintenance/164274-dayton-audio-sa230-stuck-standby-mode.html)
Sanjay Frank 01-27-17 06:50 PM
Any suggestions to (un)stuck it?
I have a Dayton Audio subwoofer amplifier SA230 that I purchased refurbished from Parts Express in Sept. 2016. I had it powering (2) Aura bass shakers (50 WPC) at the most in my home theater. It never got hot or showed any signs of dying. The only thing I did notice was that with the gain turned all the way up the shakers were still barely moving.
Suggestions in what to look for and what to repair?
Thanks,
DqMcClain 01-29-17 08:11 PM
Re: Dayton Audio SA230 stuck in standby mode
How were those two bass shakers wired? Series or parallel?
willis7469 01-29-17 10:07 PM
Did you call PE? You've only had it 4 months, is there any warranty on it? I would think so. My luck would be only 90 days lol. I'd throw the shakers and try to return the amp and get another sub.
Sent from my iPhone using Tapatalk
Sanjay Frank 01-30-17 02:09 AM
1 Attachment(s)
wired in series like this:
Sanjay Frank 01-30-17 02:11 AM
willis7469 wrote: (Post 1546770)
This is the email from the Parts Express Customer service tech:
pe tech
Jan 27 (3 days ago)
to me
Hello,
I am sorry that you have had trouble with this. It does sound like it has failed. This was a refurbished amp so it carries a 6 month warranty. You are still inside that time so I can have a refund processed for you. This would be refunded to your pay pal account. Just let me know if that is still active and I will get that set up. The Issue number for this is RA117246
Sincerely,
Chris
Technical Support Team
ajinfla 01-30-17 11:14 AM
PE is a good company
DqMcClain 01-30-17 05:17 PM
Sanjay Frank wrote: (Post 1546786)
Ok, that takes out the most obvious cause of the problem, which would be burning out the outputs with a 2-ohm load. Glad PE is on top of it with a refund... hope that all works out to your liking.
