If we want retroreflectivity as well?? - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 40 Old 01-09-09, 02:37 PM Thread Starter
custard's Avatar
custy
Re: If we want retroreflectivity as well??
with the help of harpmaker i was able to get a clear image showing the presence of glass beads in the clear retroreflective paint.
custard is offline
post #12 of 40 Old 02-09-09, 06:05 AM
Robert
I just had a wild idea..
The industry uses glass beeds for...eehhrrr..whats the word in english...removing paint and rust with a mix of high pressure air and glass beeds.
These guys:
Potters-Ballotini Ltd
Pontefract Road
Barnsley
South Yorkshire S71 1HJ
Tel: +44 1226 770381
Fax: +44 1226 207615
They manufacture it. Perhaps you can talk them into sending you a sample? Mind you, this is PURE GLASS BEEDS, so you have to mix it with with some clear "carrier".
//EDIT//
Found another one. This time you can select beed size
0- 50 m,
065 - 105 m
075 - 125 m
090 - 150 m
100 - 200 m
200 - 300 m
300 - 400 m
400 - 600 m
400 - 600 m
The price is about $60 for 25kg. Yes, minimum pakage is 25kg.
robert_1967 is offline
post #13 of 40 Old 02-09-09, 11:07 AM
Moderator Emeritus
Don
Thanks for the additional bead sources Robert!
You failed to give a name and contact info on the last source.
BTW, the term in English you were looking for is "sandblasting" or "beadblasting".
Harpmaker is offline
post #14 of 40 Old 02-10-09, 02:30 AM
Robert
Sandblasting, yes of course. thx.
Link to the supplier....I'm on it...brb.
post #15 of 40 Old 02-10-09, 04:52 AM
Robert
Here you are:
http://www.esska-tech.co.uk/esska_eng_s/
enter "70-5030GP000" in the search box.
Glass beeds for everyone :-)
//EDIT//
I have pleeded for a 500gr free sample of their finest beeds fram a manufacturer in Sweden. If I get it, I will mix it whit matt clear top coating and paint it on top of the potential N9.
//EDIT2//
I know I dont have a life :-)
But check this out
http://www.adventure-caching.de/geoc...3add019142b3aa
post #16 of 40 Old 02-10-09, 03:17 PM Thread Starter
custard's Avatar
custy
the smallest bead size i can see on the site is 65 microns which is probably larger than what we need.
custard is offline
post #17 of 40 Old 02-10-09, 04:21 PM
Moderator Emeritus
Don
Yep; nice try, but no cigar.
Does that phrase have any meaning outside of the U.S.? If not, I'll explain later.
Those beads would be too large (we are looking for beads smaller than 50 micron). I'm not sure, but I think those beads were also white in color and not clear.
post #18 of 40 Old 02-11-09, 11:59 AM
Robert
ok, just trying to pull my weight around here :-)
post #19 of 40 Old 02-12-09, 05:16 AM
Robert
With the risk of busting another unlocked door....why dont you guys just use the retroreflective paint that 3M manufacters for painting textiles?
You can read about it here
http://multimedia.mmm.com/mws/mediaw...6668OoCOrrrrQ-
Comments?
post #20 of 40 Old 02-12-09, 12:20 PM
Moderator Emeritus
Don
robert_1967 wrote: View Post
Comments?
3M makes a lot of stuff we would love to try, the problem is finding a source for it and the cost. Unless you buy stuff by the train-car load 3M isn't interested in selling to you directly.
aswell?? , retroreflectivity
