HTS-X2 - an experimental N8 reflective screen mix - Page 9 - Home Theater Forum and Systems - HomeTheaterShack.com
post #81 of 92 Old 01-31-10, 07:20 AM
John
Re: HTS-X2 - an experimental N8 reflective screen mix
Add me to the list of people using the Elekra N8 formula. Went to Home Depot and had them mix up the C&S 1850 base and the 1854 N6 and then to Michaels for the CSMS. At first I was going to go with an off the self paint as I was a little concerned about using a mix and getting it right. Harpmaker has come up with a formula that is very easy to mix up, even for someone that is inexperienced with paint. Thanks Harpmaker!!! I was able to get two coats on the wall last night. As 1canuck2 noted, it was not pretty after the first coat. The paint went on the wall really nice but did not dry well, every spotty. Second coat also went on nicely but I have not been downstairs to see how it dried. Need morning tea first. I'm hoping two coats will do the job.
John
jmuir is offline
post #82 of 92 Old 01-31-10, 11:12 AM
John
Mech, thanks for the reassurance. I did roll it. Just checked and everything looks great. Good coverage, no roller marks, etc.
I picked up the velvet, with 40% off coupon that my wife received on Friday, and wood (poplar) for the surround. I should have everything finished within the next couple hours, will need a lunch break soon.
John
jmuir is offline
post #83 of 92 Old 01-31-10, 02:11 PM Thread Starter
Moderator Emeritus
Don
jmuir wrote: View Post
Thank you for being willing to test a mix that is still in development!
Our goal here at HTS is to not only develop screen mixes that work well, but are also as easy to mix and apply as possible. A few want to say that easy mixes don't perform as well as complicated mixes, these few simply don't understand the physics and science involved in either reflective screens or projected light.
I'm glad to hear that your screen turned out well after the second coat.
Please keep us updated on your screen build!
Harpmaker is offline
post #84 of 92 Old 02-01-10, 12:46 PM
John
Harpmaker wrote: View Post
No problem. I also painted a piece of hardboard. It is about 10" x 10". I know people have already sent you samples, but would you like it? It came in handy when fine tuning the size/position of the projected image and checking for spill over.
I would say that you have accomplished this very nicely. Keep up the great work.
The screen is finished. I re-did the basic THX calibration and was able to watch a few minutes of the Pro Bowl last night. Both my wife and I thought the picture looked really good. I was surprised by how much of a difference a good surround makes. I will post more of my opinion after I get in more viewing time. I'll try to post some pics tonight.
Next I will need to pick up one of the good calibration DVDs and perform a real calibration.
Thanks
John
jmuir is offline
post #85 of 92 Old 02-01-10, 03:26 PM
1canuck2
I am curious to know how you made and mounted your frame, and where you got your velvet for 40% off, etc. Prolly doesn't belong in this thread though... maybe post up the info when you post your screenies so its at least somewhat on topic. I have procrastinated about building my frame.
1canuck2 is offline
post #86 of 92 Old 02-01-10, 03:50 PM Thread Starter
Moderator Emeritus
Don
Thanks John! That would be great! I'll PM you my mailing address.
post #87 of 92 Old 05-21-10, 11:03 AM
koyalo
Hi,
I home depot I can find Behr #1850 but not Behr #1854 anymore. They have Behr #1856.
Can I use Behr #1856 instead of Behr #1854?
Behr #1850:
http://www.homedepot.ca/webapp/wcs/s...k=P_PartNumber
Behr #1856
Thanks, K
koyalo is offline
post #88 of 92 Old 05-21-10, 04:13 PM Thread Starter
Moderator Emeritus
Don
koyalo wrote: View Post
Hi,
Behr #1850:
Behr #1856
Thanks, K
That is a really good question, and I wish I had a good answer, but it seems it's more complicated than that. Behr seems to be phasing out it's older line of interior enamel paints in favor of it's new ULTRA line that is supposed to cover better. The older paints start with 18xx and the newer ULTRA paint start with 17xx. In the case of the N6 paint for making Elektra™ it doesn't matter which series is used since so little actual paint needs to be added to color the total mix. If you can't get #1854 I would look for #1754.
The problem seems to be a difference between Behr paints sold in Canada and the ones sold in the U.S.. There is a good chance that the Canadian #1856 Accent Base is similar to the U.S. #1854 Medium Base, but I don't know for sure. I can't find #1856 at the U.S. Home Depot site.
The safest thing for you to do would be to get an N6 8 oz. sample using the Behr Accent Base and paint a small card (about 1" square) and mail it to me so I can take a spectrophotometer reading of it and make sure it really is a N6 gray. Depending on how large a screen you intend on painting, an 8 oz. N6 sample jar would tint enough Elektra™ mix to do a 130" diagonal 16:9 screen.
Just for reference, here is a link to a quart of #1754 on the U.S. HD site: http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
#1854 isn't listed on the site, but is still available in the stores around me.
post #89 of 92 Old 05-26-10, 04:43 PM
koyalo
Harp,
I went to HomeDepot here in Toronto and they don't have any of 1850/1854 anymore even though the website has them. After discussing more with the guy at HomeDepot paint dept. he told me that HD have replaced these paints with #1750 and #1754. These are same paint as #18** but comes with primer now, so a new number i.e. #17**
So I did not see any other option and bought #1750 and #1754. I am going to prepare my mixture as your formula provided for #18** and will paint the screen. I am not sure how this will affect the quality of screen but I don't seem to have choice at this point.
I can send you sample card for your testing if you can PM me your address. Also on which card should I prepare these samples?
Will upload pictures once screen is ready.
- K
koyalo is offline
post #90 of 92 Old 05-26-10, 08:33 PM Thread Starter
Moderator Emeritus
Don
The #1750 should work fine for making the C&S™ base and the #1754 will work for making the N6.
Thanks for the sample offers, I would appreciate them (will PM my address to you).
The N6 sample only needs to be about 1" square. The Elektra™ sample should be a bit bigger to try and get a sense of how it would work as a screen, something like a standard 3 1/2" x 5" index card would be great. The actual substrate for the samples can be anything from heavy cardstock or thicker. It would be nice if you could make the Elektra™ sample at the same time you make your screen so it can be a true sample of your screen (same primer and number of coats of screen mix). 1canuck2 did it that way, and Pyro2 sent me an actual 1x4 foot sample of BOC he painted with Elektra™.
Photos are always nice!
experimental , hts-x2 , reflective , screen
