HTS-X3 & HTS-X4 - experimental N9 reflective screen mixes. - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 26 Old 01-08-10, 12:51 AM Thread Starter
Moderator Emeritus
Don
For some time now we have been searching for a replacement for Craft Smart Metallic Silver paint so that people outside of the U.S. could make our Cream&Sugar™ screen mix. It turns out that CSMS is a more singular paint than we had first thought and a direct replacement still hasn't been found (maybe it has, see the HTS-X4 mix below). Another means to achieving the same goal was to create another N9 reflective mix whose ingredients could be found in most of the countries in the world.
Due to a number of reasons, our testing of these mixes has slowed to a crawl of late, but enough interest has been shown by fellow DIY hobbyists so they are being released here in the Developers forum with the strict warning that they are STILL IN DEVELOPMENT and not meant for general use or distribution yet. This is more akin to Alpha testing than Beta testing.
HTS-X3 N8.7
The first mix under trial and discussion will be called HTS-X3 and is very simple to make. It consists of only two paints that can be purchased at most artist supply stores worldwide. The only real problem is that this makes them fairly expensive unless one can find a discount source for them, but the mix is still less expensive than commercial DIY paints.
HTS-X3 is an equal mix of Liquitex BASICS MATT 'Titanium White' and BASICS MATT 'Silver'.
This equates to a ratio of 1:1 or as a percentage of each paint being 50%; of the total mix (minus the added water which we don't count anyway since it evaporates).
It is VERY important that only the BASICS MATT paints be used and not the regular BASICS line from Liquitex. The regular BASICS paints are too glossy and are slightly different colors.
In the U.S. these paints are only available in 200 ml and 75 ml tubes. I've noticed that other amounts are available in the U.K.. Generally speaking, the larger the container you buy the less expensive the paint is.
Mixing instructions:
While these paints are considered "Soft Body" acrylic paints, they are still thicker than most house paints people are used to working with. I have found that to get the paint out of the plastic tube and to thin it for application to the screen via roller or sprayer the paints need to be thinned 50% with distilled water.
To make 40 fl. oz. (1200 ml) of screen mix:
Two 200 ml tubes of Liquitex BASICS MATT 'Titanium White'
Two 200 ml tubes of Liquitex BASICS MATT 'Silver'
400 ml of distilled water
Remove the cap from a tube of paint. Empty the tube of paint into your mixing container and then carefully inject 100 ml of water into the almost empty paint tube (I have found that using a 60 ml catheter tip syringe works well for this, if you don't have one of these - be creative ). Replace the closed cap on the paint tube that is now half full of water. Shake the paint tube hard. I have found it works well to actually smack the tube against the bottom of the palm of your hand. The idea of course is to get as much of the paint sticking to the inside of the tube into solution. Empty the water into the mixing container. Repeat for each tube.
Mix the paints and water throughly and you're done.
If you are rolling the mix you might want to let the mix set a few minutes for the air bubbles from mixing to escape.
If spraying, thin as needed with distilled water for your sprayer.
HTS-X4 N9
All instruction for HTS-X3 above apply to this mix as well. The only change is in the ratio of the paints.
HTS-X4 is a 2:1 mix of Liquitex BASICS MATT 'Titanium White' and BASICS MATT 'Silver'.
To make 30 fl. oz. (900 ml) of screen mix:
One 200 ml tubes of Liquitex BASICS MATT 'Silver'
300 ml of distilled water
While this mix is seemingly the equivalent of Cream&Sugar™, it has not been fully tested yet and may not perform as C&S™ does.
Harpmaker is offline
post #2 of 26 Old 01-08-10, 02:24 AM
Altern8's Avatar
Rob
Re: HTS-X3 - an experimental N9 reflective screen mix.
I will try to get these tomorrow!
Initially I will start small but have you any idea how much would be required to paint say a 100" screen?
I looked at this on the Liquitex website. The pigments listed are just TiO2 and TiO2 coated mica. So to increase to N9 by adding more white a ratio of perhaps 2:1 might be a good place to start (if the Titanium White is 9.4 to begin with). Might be easier to add the paints by weight if this ends up an unfriendly ratio. Would going from 8.7 to 9 be noticeable (aside from the reduction in mica)?
Also, is this mix spectroed as neutral?
In order to assess potential hot-spotting, what would be the minimum size for a test panel that you would recommend?
Altern8 is offline
post #3 of 26 Old 01-08-10, 06:39 AM Thread Starter
Moderator Emeritus
Don
Altern8 wrote: View Post
A 100" diagonal 16:9 screen has 29.6 square feet of surface. I find that I usually end up applying about 1 fl. oz. of total paint per square foot so I would recommend having about 30 fl. oz. of mix to paint that size screen.
To answer the last question first; yes, this mix is VERY neutral. Much more neutral than the mix made with the regular BASICS paints of the same color (which are too glossy anyway).
The Ti-White is actually a N9.7 I believe, but I'll have to look it up. Changing the ratio of the mix to 2:1 Ti-White/Silver would definitely lighten the mix. I don't see where I tested that ratio with the MATT paints (I thought I had) so I will do so today.
There is, of course, a visible reduction of reflective properties when the silver paint is reduced to 1/3 of the mix, and such a mix is visibly brighter than a mix where it is 1/2 of the mix. I'll have more data after I make the samples.
I really don't like the idea of weighing out paints; unless large amounts are done at a time I would think it would be quite a bit less accurate than measuring by volume, but to be fair I never tried it.
There are differing opinions of this. Some say you need to make a full screen to tell if a screen hot spots or not (which I don't agree with). Some say a 2x4 foot panel will do. Personally, I have found that a 1x4 foot panel is enough, and you can get a good idea if a mix will hot spot or not just from a 1 square inch sample after you develop an eye for it.
post #4 of 26 Old 01-08-10, 12:34 PM
Altern8's Avatar
Rob
Harpmaker wrote: View Post
The brochure lists hue, value and chroma numbers so I assumed this was the Munsell system. If so 9.39 is the value for Titanium White. Does seem a bit low though.
A 2:1 mix would have 66% of the reflective particles of a 1:1 mix. I wonder if this reduction would have a huge effect. On the other hand going from 8.7 to 9.0ish would probably be barely noticeable?
There is also a Neutral Grey listed (4.7). Mixing the 3 paints could give a wide range of adjustable N values. I wonder how neutral their blacks are?
I'm luckier than most as I have access to forensic lab equipment that can weigh or measure very accurately. Handy for testing but I know the desire is for simple solutions. Given that the mix is so neutral the accuracy of measurement would not be critical.
Altern8 is offline
post #5 of 26 Old 01-08-10, 03:18 PM Thread Starter
Moderator Emeritus
Don
You are correct that they use Munsell color data, but it is given for D50 not D65. While that shouldn't make much difference with a white or neutral paint...
The only way to tell what difference a change of formula really has is to make a test panel and look at it under PJ illumination. PJ light is very directional and that does make a difference. The best way I have found to mimic this is by using a bright L.E.D. flashlight on the small sample I make for spectro tests.
The difference between a N9 and a N8.7 is detectable, but very minor. I would be surprised if people could tell the difference without a literal side-by-side test.
Yep, I noticed. When we get this current formula finished the next step will be to mix it with the N5 to make a mix series similar to Elektra™.
You seem to have been bitten by the Screen Developers bug. Come on in, the waters fine!
Now I'm envious.
Our goal is to make screen formulae that work well, are easy to mix and have a certain amount of "fudge factor" thrown in so that small errors can be made by the end-user or paint store and still get a neutral screen.
post #6 of 26 Old 01-08-10, 07:26 PM
Altern8's Avatar
Rob
I managed to get a few tubes at a local hardware store today (white, silver and grey). 75ml is all they stock and quite expensive so I will get some more online. One website has 946 ml of white for NZ$28 but the silver is 118ml/$5.60. I'll keep looking.
At least I can get unlimited amounts of distilled water!
I have a couple of offcuts from my screen panel that are only 8" wide but ~3' long. I'll use these for my initial tests.
I've told "her indoors" that I'm only doing this until I have the new screen for my Panny 4000. She says I have too many hobbies already (coaching and playing football will take up a lot of my time real soon).
Its a glorious summers day here today - too hot to paint methinks!
Altern8 is offline
post #7 of 26 Old 01-09-10, 09:18 PM Thread Starter
Moderator Emeritus
Don
Re: HTS-X3 & HTS-X4 - experimental N9 reflective screen mixes.
Just measured samples of Liquitex BASICS MATT Titanium White, HTS-X3 (1:1) and HTS-X4 (2:1).
Matt Ti-White = N9.7
HTS-X3 = N8.7
HTS-X4 = N9
While there are still visible reflective flakes in the HTS-X4 they are not as evident as in HTS-X3.
First post edited and HTS-X4 data added.
post #8 of 26 Old 01-10-10, 06:48 PM
Altern8's Avatar
Rob
Just sprayed my first test panel with HTS-X3
Used 75ml of each paint + 75ml Distilled water. Added another 25ml water for spraying, possibly thinner than it needs to be. First go with the Wagner seemed to go pretty well although I probably put too much on for the first coat. Its drying flat to avoid runs. I'll get the hang of it eventually but already a convert from rolling!
I am making a matt N8.7 from Dulux Vivid White Flat and tiny amounts of a neutral black for comparison. Doing this by eye but should be good enough to assess reflective properties and any hotspotting issues.
Altern8 is offline
post #9 of 26 Old 01-10-10, 07:16 PM Thread Starter
Moderator Emeritus
Don
Better the mix is a bit to thin than too thick when spraying. Yeah, it takes a bit of practice before you get the hang of spraying, but then "it's all gravy".
If I remember right I think both Mech and I determined it takes about 3 coats by spraying to equal one coat by rolling. I think almost everyone starts out spraying on too thick a coat and get runs, but after you learn how thin to make the mix and how fast to move the gun it's easy as pie.
I have yet to find a neutral black paint. About the closest I have found is Liquitex BASICS MATT 'Ivory Black'. It turns out that most blacks are really very dark blue.
Feel free to send me any samples you want tested for spectral reflectance. I'm quite sure Mech would be happy to test them too. I only need about a square inch of paint to actually test, but an index sized sample is better in case an area gets damaged in the mail. Just PM me for my address if you're interested.
post #10 of 26 Old 01-10-10, 07:37 PM
Altern8's Avatar
Rob
The black I'm using is this one. RGB is 54 53 53.
I don't ever intend to use this in a real screen paint. I just want to make a non-reflective matt paint to compare with HTS-X mixes and assess the effectiveness of the mica.
I will send samples to both you and Mech soon!
Altern8 is offline
experimental , hts-x3 , mix. , reflective , screen
