SI Black Diamond clone? - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 47 Old 07-30-13, 04:35 PM
Banned!
Rob
Re: SI Black Diamond clone?
I know this discussion is old but I think it is still topical and I have something to add!
Firstly, just for information, Black diamond screens (made by DNP) use microscopic louvers printed into the material which is why that component of the design can't be achieved with a paint brush or roller. DNP is a large Japanese printing group mainly so they have access to large printing presses.
In terms of performance, even black diamond screens can't reach the standard they claim. It is great marketing though. There is no screen that works well in high ambient light with a standard home theater projector. They are too dim and the black version of that screen is only a 0.8 gain. The more popular 1.4 gain screen is a lighter grey color and neither looks like a plasma or even that different to other grey screens. The best either will do is look ok with a small side light on. If you look at candid user photos, you see a slightly less washed out picture in a bright room but not even close to perfect. Like I said, great marketing though.
There are some aspects of the design that can be replicated such as a near black screen surface. I will include some pics of the black-screen material I made at home. I painted my surface a glossy black. Under the black was a layer of aluminum that was already dry (the real BD screen is held rigid by a piece of aluminum sheet). When the black was dry, I added a layer of semi translucent / semi transparent screen paint using a spray gun to give it a smooth finish. The result looks like dark grey when not in use and black when on. It is really a 3 layer screen.
To test it, I had bright lights above it, another light directly beside it and the sun shining in through open blinds directly behind it. The sun light was directly in the projectors path which everyone will tell you is a tough situation for any screen. Instead of comparing it to matt white like SI does, I thought it would be more useful to compare it to a screen painted with screen goo, high contrast grey paint. This would be a standard commercial paint recommended for use where ambient light can't be controlled right?
The projector used is only a 2000:1 contrast ratio. Check out the candid photos. I think you will agree that the test room is bright and that I am achieving decent blacks considering how bright the room is? So how important are those micro louvers that you can't replicate? With a bright enough projector, not very important at all and I don't think they do that much.
I could do one more thing to make it closer to BD which is add a layer of glass at the front. BD knows that a clear image needs a smooth surface. Glass is a good way to give you a smooth surface if, for example, you covered the screen underneath with tiny printed louvers. It also adds some reflectivity which is helpful if the rest of the surface is not reflective black. The problem with glass, which BD also suffers from, is hot spotting so position of your PJ is important. A solution I haven't tried, which I think would work, is to use frosted glass and have a black surface behind it. The glass would still need to be semi transparent though. BD is a heavy screen and for this reason, I left mine without glass.
Let me know what you think of the pics. Sorry they are a little grainy. I add to downscale them to upload. The originals look super clear but you can still see the blacks.
Daylightuser is offline
post #12 of 47 Old 07-31-13, 05:48 AM
Hi Rob!
Did you manage to paint the translucent paint evenly across the sheet? Translucent paints are extremely hard, if not impossible to paint. If the paint gets a bit thicker on one part of the screen, you will get hot spotting. I've tried translucent paint in big scale but I quickly gave up.
Regarding the glass, I've tried that too. Frosted glass is not the way to go, makes the image blurry and nothing else. I also tried using frosted film, gave me more gain but it also gave me a shimmering and sparkling image. Technically, if you had a bright enough projector, you could use a black painted screen as a projector screen, but yet again we're talking a super bright projector. If you take a completely black paper and put it in front of the projector, lets say a 15" screen, you'll get a great picture with awesome blacks.
Mechman, I've gotten some test samples of mylar and I will try to mount it on plexiglass later this week. I've mounted tinted films on cars before with good results, the trick is to use two or three drops of dish soap in 1l water and then use a LOT of the water and soap mix. You can't use too much of it, spray a lot on the surface you're going to mount it on, a lot on the film as well, and even on yourself and the surroundings to prevent dust getting stuck between the film and the glass.
/Patrik
Patrik is offline
post #13 of 47 Old 07-31-13, 05:53 PM
Banned!
Rob
It's hard to see exactly how bright the room is from photos but I can tell you that the room is well lit from 3 directions. A good portion of the light is sunlight coming in from the large double window facing the screen. The projector is in front of the window and the test was done in the middle of the afternoon.
Other than being outside, it doesn't get much brighter than this. You can see how the "high contrast grey" screen from screen goo struggles to give a visible image. The black screen is watchable.
On the translucent paint, yes it was very hard to get an evenly painted surface using a roller. The best I achieved was using a screen printing roller which is solid plastic instead of soft foam etc. Even then, it only gave a good image when you stand back. In the end, I bought a sprayer from home depot for $80 which did the job easily and quickly. I feel like my bones are still vibrating from the noise of it.
It is a shame I had to reduce the quality of the image to upload them because what you can't see is how sharp the picture is. I wanted to see if it is possible to create a version of black screen technology at home and I concluded that it is. I also believe there are better ways to do it than this now I understand the principle.
I am currently experimenting successfully with a similar screen type which uses a charcoal colored rear projection fabric with a solid reflective coating on the back to turn it into a front projection surface. I want the front surface to be fabric instead of paint to make sure it is smooth. All of the high priced solutions advertise a "multi layered" technology although they tend to be somewhat evasive on further details. I have seen dozens of patents described for projection screens and very few of them from screen innovations and DNP. They are all there for anyone to read and it is worth doing a little research to understand the science when designing your own. You don't have to worry about patents for your own mix. The Sony Dynaclear uses a dichroic coating to make it "selectively reflective". Essentially a multi layered coating that only reflects red, green and blue light from the projector and nothing else. Who says it is impossible to make your own dichroic coating or to get a company to make one for you?
I think this is where home solutions fall down sometimes. Mixing paint doesn't always give you the properties of both colors. For example, red pigment is great at reflecting red light, but it also absorbs green and blue. Mix red, green and blue paint and you will probably absorb all of them and get a very dull image. That is why you sometimes don't achieve the increase in gain you might expect from mixing reflective paint like aluminum into your mix. The challenge is finding something to enhance reflectivity where you want it and not absorbing colors you do.
Mixing water based aluminum paint with white or beige gives me a grey paint. In theory, this is meant to have a much higher gain than just using a ready mixed neutral grey which is made from black and white pigment. The trouble is that I couldn't swear that the difference in gain is that significant. I'm sure others have had better results than me but there has to be a reason why aluminum paint isn't generally used in high end screens.
I bought some Speedball aluminum ink which is used for screen printing and some newton and windsor aluminum ink. Both will mix with acrylic or water based paints. I found a significantly greater improvement in gain than I was able to with Auto-air water based aluminum paint. also, with the speedball roller, I found it a lot easier to get a smooth and consistent finish. I couldn't tell you why but I have a feeling it is something to do with the greater saturation you get with ink over paint. Mixing the silver ink into white or beige paint and the end result still has a metallic look instead of turning to light grey. You still get a watchable screen without hotspots, only much brighter. Silver ink can even make black paint reflective enough, to use with the right projector, without turning the paint light grey. I am experimenting with this right now.
I am a fan of black widow mix generally. I added some aluminum ink to my black widow paint mix and it closed some of the gap with more expensive high gain screens. I have tried a lot of these commercial offerings btw and I am almost always disappointed. None of the big players have a right to claim "innovation" in this space in my opinion. The elusive commercial screen that works well in all conditions, with all projectors and at a price that doesn't singe our nose hairs, has not been created yet. DNP charge $25K for their flagship screen. It may be great, it is a shame that hardly anyone will ever know so it is irrelevant.
I will try and upload a video link to Youtube to show the black screen in a way that shows how bright the room was and where the light was coming from.
Last edited by Harpmaker; 08-01-13 at 05:09 PM. Reason: Text modified slightly to meet forum rules.
post #14 of 47 Old 07-31-13, 06:06 PM
Banned!
Rob
Patrik
I am interested in what you were saying about frosted glass. Perhaps I can learn from your experience and save myself some time and cost.
Was the surface of the frosted glass you used smooth or rough? Did you try it with a smooth film over the frosted layer? Also, did you try it with a black layer behind the glass?
I ask because I found that taking some anti glare plaxiglass and painting the back with aluminum paint, gives you a watchable projection surface, even if the aluminum paint is not evenly spread.
People always warn against mylar because it has a mirror-like finish but I have wondered how it would respond with a thing translucent light diffusing layer on top. It is designed to reflect light. I have experimented with one way mirror window tint film. It doesn't do much for reflectivity once you add paint but it does give you a really smooth surface to paint on which helps the finished layer.
There are tons of window tint films on ebay specifically designed to reflect, absorb, or transmit light in a very specific way. The right combination could probably make a good multi layered screen.
I want to try it with a tinted layer, reflective layer and then use glass bead (powder consistency) as the front diffusing layer for a retro reflective screen experiment.
post #15 of 47 Old 08-02-13, 07:46 PM
Banned!
Rob
BTW, I was thinking about a DIY optical louver solution and it occurred to me that this is how the privacy screens for computers work. 3m makes those micro louver film. I am getting a price on some custom sized ones. If anyone has one on their monitor, I would love to know what effect it has when you hold it in front of your projector screen?
post #16 of 47 Old 08-06-13, 02:37 AM
Daylightuser wrote: View Post
Patrik
You have some great ideas Rob, thanks for sharing!
Regarding the tests with frosted film: First I tried with a frosted film (somewhat rough surface) painted with a mix consisting aluminium and black paint on the back of the frosted film. The result was a dark grey screen with a gain of somewhere around (guessing) 0.8, though, the picture got to shimmery and sparkling due to the rough surface of the frosted film.
So, I tried with a smoother frosted film, but that did't increase the gain that much, no luck there neither. After a while I started having doubts of using a frosted film at all, they didn't help making a darker grey screen. The smoothest frosted film I found who didn't shimmer at all was the one I made my self. I simply sprayed a layer of matte coating on a transparent film, but as I said, frosted film didn't serve any purpose, spraying the matte coating directly as the top layer was the best way judging from my tests. I tried with a black layer behind the glass, but I only had the rough frosted film available at the time, but I guess it would simply give us a very dark low gain screen, I can try this tomorrow and get back to you with results!
Rob, regarding the anti glare plexiglass, even though it is an anti glare surface, do you see any reflection from the projector lens? What is the purpose of painting the aluminium paint on the back when the plexiglass is transparent? Also, do you experience a shimmering effect from viewing directly on the aluminium paint? Seems like hot spotting would be a fact unless you finnish of with a matte top coating.
I'm excited about getting started with the reflective films. My idea is following: Mount a reflective film (Mylar for example) on plexiglass or similar smooth surfaces (PET is a very good alternative, much cheaper than plexiglass), on top of that, mount a translucent slightly black tinted film and then finish of with a top matte coating. On the back of the plexiglass or PET glass, mount a matte black fabric or paint matte black in order to stop any unwanted light passing trough (a black background is much better than white in this case since we're only interested in the light reflected by the reflective film).
Regarding the privacy film, I think the viewing cone will be so narrow that you wouldn't be able to see the edges of the screen. What is your ambitions with the privacy film? If you get your hands on this privacy film, how do you plan to mount it? However, if it works I could imagine it wouldn't send any light outwards to the walls and ceiling, only right back to the audience (just as it does with a computer screen). I have my doubts though.
Rob, I'd love to see a youtube clip of your test! What is the gain of your test screen guessing?
Regards, Patrik
Patrik is offline
post #17 of 47 Old 08-06-13, 01:09 PM
Banned!
Rob
Thanks Patrik
The purpose of painting the aluminum on the back of the plexiglass is to take advantage of the smooth surface instead of trying to paint a perfectly smooth surface which is not possible. Black Diamond screens have a glass front and my guess is that it is for the same reason. Also, anti glass plexiglass eliminates the shimmer. As for hot spotting, like BD, you will get some unless you position your projector on a different axis to your viewing angle. For example, a ceiling mounted projector pointing diagonally down towards the screen would work. If it was on the same level as your eyes then you would see the reflection. From the testing I have done with this, I would consider making that sacrifice because the results were so promising.
When it comes to films, 3M make a bunch that, on paper at least, sound perfect for our purposes. The problem seems to be the quantities you have to buy them in and therefore the cost. For a roll with a 60 inch width, they come in lengths of 100 feet and cost around $8000. Fine if you were starting a business but not so great for just 1 screen. Especially as need 3. ! reflective film, 1 tinted film and 1 light diffusing film. I bet the results would be good. The light diffusing film would take care of all hot spotting issues as that is what it is designed for. So that leaves us either trying to get enough people to make it worth it, or finding cheaper alternatives which I'm told are not usually in the same league as 3M products. As the old Zen Master say "we'll see". Either way, I am convinced that I want the front layer of my ultimate diy screen to be film instead of paint. The increase in image quality with a perfectly smooth surface is worth some sacrifices for me. Now that I have seen the Sony Dynaclear, I know there is no other way to go. Pro screen makers always talk about increasing contrast with "tint". I am fairly sure they mean tinted films as one of the layers in their"multi-layer" screens.
On the "privacy film", I want the micro louver effect. This is how BD and similar black screen technologies work in brighter conditions while not being massively higher in gain. They use those micro louvers to block light from certain directions and allowing it in from directly ahead (like your projector). That is one of the reasons why these screens have a narrower viewing cone than others. Some of these are also retro reflective which is another reason for the narrow cone but the cone would be narrow anyway so it doesn't matter for them. If you look at the reviews, they show a fairly steep drop in brightness (like 50%) when you get too far off center. In reality, for most people who have a large screen at home, the seating would be in front of the screen unless they have a very wide room and too much furniture. I guess those people wouldn't want any kind of retro reflective screen anyway.
On the privacy films, these work in the same way. They block light front the sides and allow light within a 60 degree cone to pass. As it is the same technology, I see no reason why it couldn't be adapted to the projector screens if you can get one that is large enough. I am getting a quote on such a film as we speak. I have asked for pricing on a custom 100 inch version. As it is a custom film, I am assuming that I will also be able to specify changes such as broadening the viewing cone if the privacy screen spec proves to be too narrow. 60 degrees though sounds similar to some of the high end screens anyway. One of the problems (in my opinion) with the commercial screen manufacturers is their desire to keep everything a secret so they can charge a lot of money for what is essentially a piece of transparent film with horizontal lines printed on it. That secret, while understandable, means they are limited to designs that preserve the secret. I was thinking that, just like privacy screens, the micro louvers film should be removable to give you options. Essentially the best of both worlds. When it is bright, you block the light from the sides and put up with a narrow cone. For the occasion when a bunch of friends come over at night and you need a wider cone, you take it off. This assumes you don't also use a retro reflective only screen. I say only because some of the glass bead screens I have been experimenting with are really bright when directly in front of them but are also still watchable from the sides if the room is dark.
On the gain of my screen, I am assuming you mean the "black screen" I pictured on this thread (I have posted a bunch on other threads too)? I don't have any special equipment to test this and I have trouble distinguishing performance in bright conditions between improvements caused by contrast vs gain. I would guess that the screen pictured is about a gain of about 1. That being said, next to a window on a sunny day, it is far more watchable that a screen I have with a gain of 2. Increasingly, I am finding that a higher gain on a white screen can make the problem worse. You have a higher gain to help with ambient light but without using some pigment to make up for the projectors lack of ability to produce a real black, you end up with a bright but still unwatchable washed out image. When I added aluminum ink (not paint) to the back, I saw an increase in gain to perhaps 1.4. I saw a similar increase when I added some aluminum ink to my black widow mix.
Based on my experiences, if given a choice between a high gain screen and a high contrast projector vs a high brightness projector and a high contrast screen, I would go with the latter if watching in bright conditions was my goal. I remember reading somewhere that after 5000:1 the human eye can't detect additional increases in contrast so when you see projectors with 30,000:1, this can only be measured with equipment and at 5000:1 it would look the same. I mention this because we are starting to see super bright professional projectors with 8000:1 contrast ratio which will do a lot more to help with light conditions. If you have a home theater projector with 1000 lumens and a 50,000:1 ratio, nothing will help with the curtains open. For me, black screens help you get a good image from a bright projector in a bright room. That said, the magazine could be wrong. Has anyone heard a different number for how much contrast the human eye can detect?
I have plenty of footage of my experiments. I will go and upload it this afternoon and post a link. I took the footage to show how bright the room was from all angles which you can't capture in a photo. I would caution that it is hard to see gain in video footage or photos as they always seem to differ from what you see in reality. They are good for comparisons though.
post #18 of 47 Old 08-07-13, 12:52 AM
Banned!
Rob
As requested, here are a bunch of links to video footage of my black screen tests. I have tried to show how bright the room is in each case. The first two show a comparison with a grey screen. It is worth noting that the room was bright enough that It was tough to obtain a watchable image with any other screen types, including my grey fabrics. This makes it tough to find a good comparison for quality purposes but I guess that is the point.
The first one shows a half and half comparison (bottom half is screen goo "high contrast digital grey". The top half is a strip of an early version of my diy black-screen material):
2nd. Again for comparative purposes, a screen goo, high contrast grey screen with a strip of an early version of my black screen material. This was the test that encouraged me to keep experimenting with this method. I wanted to compare it to a high contrast grey screen to make the test meaningful. All white screens suck in light. The screen goo high contrast paint wasn't much better to be fair. Don't waste your money on it. It is high contrast in name only:
The next lot are all tests of various versions of the diy black-screen mix only. Some of them are cruder than others depending on where I was in the process. You will see some imperfections on the earlier versions but they all taught me something. Only the final version is totally free of imperfections as I purchased the paint sprayer. The rest were done with a roller which is hard a hell to get an even coating for translucent paint. There is also one which is just projecting onto black material with a bright projector for fun but the rest are all black-screen tests.
Lastly on the black-screens, one with a different angle - thought I'd try an early version of the black-screen by the window with the blinds open to see if being closer to the day light makes a difference:
For a bit of variation, check out this diy glass bead screen test. Powder sized glass beads over aluminum ink:
I know this one isn't in the least bit relevant to this thread but I think it's cool anyway. Check out my transparent glass TV:
post #19 of 47 Old 08-07-13, 04:15 PM
Banned!
Rob
Really bright sunlight today so perfect for testing my tinted film concept for making a diy black-screen.
As a baseline, here is a video of my black widow screen with a bright projector to show how bright it is. Even the black widow surface struggles to look anything but washed out and that takes a lot of light. I am a black widow fan and it normally gives good results with some ambient light.
Check out some of these pics. The third shows a translucent light diffusing film for front projection with a black cloth on the back to stop light getting through.
The 1st shows light diffusing material used for rear projection. In my opinion, there is nothing in front projection that works as well as comparable rear projection materials in bright conditions. It's a shame they are so annoying to set up. I prefer the way rear projection looks.
The 2nd shows the same light diffusing material used for front projection. It looks washed out as it is far from opaque. The 3rd is the same material with a black cloth covering the back to stop light getting through. Much less washed out. Almost watchable!
The 4th shows a roll of simple dark window tint with a glossy white material on the back. This tint is far too dark but still a useful first test. It definitely works to a point and I see potential. This is a 5% tint which is barely see through at all. I have ordered some 35% and 50% tint to try (higher percentages mean less tint. dark limo tint is 5% and 80% hardly has any tint). This is to test my theory that high end screens achieve contrast with layers of tinted film instead of mixing darker paints into their mix. These window films are cheap. While not directionally light rejecting like more expensive filters, they are anti glare and non-reflective which should be perfect. As you can specify how much visible light to let through, it should only be a case of finding the right one. I believe that using layers like this instead of mixing paints will give stronger properties of each layer than I would get by mixing them into one painted layer. We'll see. Check out this video clip too.
The light reflection is from my camera, not the projector before anyone shouts hot spot!
The 5th was taken later on when the sun went behind some clouds and to room got a little darker. I used the opportunity to get another pic of my black widow screen to show that it performs well in ambient light (just not as much light as the black-screen). Still a solid performer!
The 6th pic is the results using a white surface in the same conditions with the same projector for comparative purposes. As expected, washed out and unwatchable, even with a bright projector.
Now check out this clip showing the light diffusing material with a coating on the back of aluminum paint. It's hard to tell exactly from a clip but it looks great. So clear and bright. The only thing is that after 5 layers of that auto-air aluminum paint, light is still getting through. I'm not a huge fan of this brand for that reason. I think that 5 layers of any paint should stop light getting through. If I'm relying on this paint for reflection when mixed with other paints, am I loosing some of its effectiveness if the other paint is opaque and dominates over the aluminum??? It makes me want to redo the black widow with an additional 5 layers and twice as much aluminum paint to see. ...
I am going to follow up with a few more pics in a bit.
post #20 of 47 Old 08-07-13, 04:27 PM
Banned!
Rob
For comparative purposes, some more pics taken at the same time as the ones in the last post.
Pics show a comparison with my diy black-screen mix, diy black-screen next to my black widow screen and the tinted film again.
Also, as a small warning to others, I have included to pics of Rosso screen materials. Rosso's black front projection fabric, which their website describes as "perfect for front or rear projection" is possibly the least reflective material I have ever seen. Look how dim the image is up close with a 7000 lumen projector. The asthmatic colors are barely visible. With the average home theater projector, you wouldn't even know it was on. Stay well clear as tempting as it is to try their relatively inexpensive screen fabrics. They clearly don't test them themselves so you can't trust the product descriptions on their site. It's easy to see why I am skeptical about claims that manufacturers make about their screen materials. The fine line between exaggeration and lying gets crossed regularly as they know we have no way of measuring their claims on gain etc. Most people don't have a second screen for comparison either.
Rosso's silver fabric, which isn't even close to silver, is also pictured. It is more of a light grey color sort of works in a washed out kind of way. It looks the same for both front and rear projection and may be better with a black backing although my attempt to try this didn't give much improvement to date. It's a shame, Rosso are a well known company and I had no reason to no believe them before. They sell 20 different screen fabrics with multiple colors of each. There is no reason to claim a materiel works for projection when it doesn't. I am going to try stretching the "silver" to see if it can be used as a layer of a high contrast screen.
black , clone , diamond , si
