'Pigment' Free Gray- Initial Development and Testing - Page 4 - Home Theater Forum and Systems - HomeTheaterShack.com
post #31 of 82 Old 12-04-07, 11:00 PM
tradewinds
Inactive
Posts: n/a
Re: 'Pigment' Free Gray- a New Gray
mechman wrote: View Post
so far this one appears to be the one that may replace my trusty sheet of Fashion Grey laminate! It appears that good!
mech
mech, when you take the next round of pics, can you do one with the FG laminate also? Just curious. Thanks.
post #32 of 82 Old 12-05-07, 11:12 AM Thread Starter
wbassett's Avatar
Bill
...snip
I'd see no problem painting over a laminate. ...snip
Other than the waste of a great screen and a very expensive substrate just for painting.
wbassett is offline
post #33 of 82 Old 12-05-07, 11:20 AM
tradewinds
Inactive
Posts: n/a
What's the best substrate to roll on for that size screen?
post #34 of 82 Old 12-05-07, 11:59 AM Thread Starter
wbassett's Avatar
Bill
You can do a 100" diagonal screen with many substrates. The problem comes into play for larger screens that are over 100" because that exceeds the 4'x8' size of the typical sheet. You can eek out 100" because it is actually 49" wide, but that will be using the entire width of the sheet as the screen height, so you won't be able to attach it to a border. What most people do in that case is mount the substrate to the wall and then build the frame around it.
If that is the plan, it is usually easier and cheaper to just paint the wall itself. If the wall is uneven, that can be remedied too. Here is one way to do it.
Other options would be to use painter's canvas or BOC and paint that. Right now I am working on a tutorial to make a quick and easy BOC screen that can be used as is or painted.
Unless you want to back light your screen like some people have done, or make a 'floating' screen... or if there is a reason you can't use the wall (like you rent and can't paint the wall itself), using a wall as your screen surface is probably the easiest and most economical way to go.
If you go with a substrate, 1/8" hard board will work, but it is a bit flimsy and bows unless it is attached to a frame or directly to the wall. Laminate will too though. 1/4" is much stiffer, but the weight is also much more. Some people have used MDF and with that the weight really starts to skyrocket.
An alternative if you are going to be painting would be a sheet of sanitary panel like Parkland Polywall. Many have used that as either a white screen as is, or as a substrate to paint. The key is to make sure it is a smooth surface. You don't specifically need Parkland if you are going to paint. Most home renovation centers carry this between $10-$15 a sheet. Again, make sure it is smooth, some are textured, but the back side is usually smooth. Prime it since it is a plastic material. That will make sure your screen paint has something to bite into and adhere well and will help prevent peeling down the road.
Here is another relatively inexpensive and light weight option... paneling. I have used smooth surface paneling scraps as test screen panels and they have worked out well. Most paneling has grooves though to simulate the slotted tongue and groove look, but the backside is always smooth. I have to give a disclaimer though, I've never used paneling for a full size screen but I don't see why it wouldn't work and be just as light weight as any other plastic substrate.
Pretty much if you are going to paint, anything will work if it is smooth and prepped right. The only restriction is the screen size. If you only need a 100" diagonal or less screen, there are more viable options than you could ever use... if you want a larger screen, finding substrates over 4' wide can be difficult or even impossible without special ordering. Depending on where you live I should say.
DW really is an outstanding screen though. Any particular reasons why you may be changing your mind from using it?
wbassett is offline
post #35 of 82 Old 12-06-07, 12:58 AM
I was just thinking... my screen is 97" diagonal, which means it should be 48" high x 85" wide. I can paint something and mount it inside my border trim, thereby eliminating part of that border trim depth on the inside edge.
So yeah... what would be the best material to paint... 1/2" MDF maybe? I could paint it and then hang it.
Sonnie is offline
post #36 of 82 Old 12-06-07, 12:59 AM
And when is this stuff going to be ready?
Sonnie is offline
post #37 of 82 Old 12-06-07, 01:39 AM Thread Starter
wbassett's Avatar
Bill
Very soon.
We ran into some trouble with availability of the main ingredient and had to find a suitable replacement. Jim found one and the spectro tests and spectral curve is one of the flattest we have seen in anything so far. Then we had to find a white base that was also neutral or closer than other whites out there and wouldn't skew it too far out. Now we're doing some more test panels and going into the final stage. We just did not think it was responsible to jump the gun and present something and then have to tell people they couldn't get the most important ingredient. (It was discontinued, so it was worse than being a regional item) Or worse, present something and then after some in depth testing discover there is a major push or problem with it and have to tell people not to use it or make a change right after presenting it.
So things started out on a rush of excitement, but then we stepped back and had to make sure this was something that people could get and make, as well as verify the specs and performance. All in all it may seem like a long time, but this was introduced at the beginning of October and now we're almost done. That's a much faster pace than it would take a commercial endeavor as well as most other DIY applications, many which still undergo major changes even shortly after being introduced.
Anyone that knows me knows I am pretty solid on things. The only change in the laminate screen world is that we took some new readings and found a better option than Fashion Grey, not that FG is bad, we just found something that has a better color balance and we formally have said that. It took a year though to dethrone FG and anyone that has used it for a screen will still have a great screen.
The same philosophy goes with the OTS neutral and near neutral grays. Since they were introduced, the list of identified and tested neutrals has not wavered or gone through monthly mix adjustments. They were solid last year and are solid this year, the only difference is a few more were added to the list from different manufacturers.
PFG will be the same. When it is unveiled in the next few weeks it will be a finished DIY application and I do not foresee any changes being made to it a month later or even a year later. People wanted something more advanced so that was researched. After this, we plan on working on optical coatings (actually that work is already underway) as well as making frames and borders easier and more professional looking.
Like I said, 2007 has been a great year and 2008 will be better and more interesting!
wbassett is offline
post #38 of 82 Old 12-06-07, 01:46 AM Thread Starter
wbassett's Avatar
Bill
Sonnie wrote: View Post
MDF is wickedly heavy. It will work but to me is heavier than it needs to be, especially the 1" thick stuff. For a 97" screen there are many options, but from talking to you your biggest hurdle is getting that border off that was put on with Liquid Nails! I have done some wood work and saw the wood break before the Liquid Nails gave way. That's some pretty strong and permanant stuff.
The screen I will be making as a tutorial for the PFG thread will be a cloth screen that is painted. I will be using BOC, but anything that can be painted can be used, canvas, MDF, 1/4" hardboard, sanitary panels, even paneling could work. Over 100" diagonal though is when the options start to get slim and fast. Sonnie when you're ready to change screens I don't think you'll have a problem getting a substrate in that size.
wbassett is offline
post #39 of 82 Old 12-06-07, 08:53 AM
tradewinds
Inactive
Posts: n/a
wbassett wrote: View Post
The truth is I have not tried the DW as it is still in the box. My PJ is a Infocus 7210 and since it is bright without an iris I was hoping to get better PQ with some ambient light on while watching sports. My HT room has dark walls, ceiling and floor.
post #40 of 82 Old 12-13-07, 04:27 PM
Sonnie is offline
development , free , gray , initial , pigment , testing
