Sherwin-Williams Pro Classic Satin Extra White - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 5 Old 12-30-14, 11:32 AM Thread Starter
Oleson, M.D.'s Avatar
TXFlyGuy
Projector Central used this paint, #B20 W 51. They claim to have a near perfect screen with this product. They stated that with today's projectors, you are better off with a white paint, not gray.
Anyone here experimented with this? Good results?
Our 155" screen is painted with Behr Silver Screen and Behr White Opal Pearlescent (3 to 1 ratio).
Oleson, M.D. is offline
post #2 of 5 Old 01-01-15, 11:05 AM Thread Starter
TXFlyGuy
Re: Sherwin-Williams Pro Classic Satin Extra White
mechman wrote: View Post
Projector Central is a good starting point for researching projectors. It is also a terrible place to research a diy paint for a screen. Not quite as bad as avs but close.
So to answer your questions, yes and no. Search and you will find answers.
We are considering a DIY paint upgrade (if possible) to our existing screen.
Panasonic PT-AE8000U
155" screen (Behr SS / Behr White Opal Pearl)
23 foot throw distance
Dedicated home theater, light controlled, dark maroon walls/ceiling/carpet
Can you point me in the right direction? Here is a previous post: DIY Screen - 155" Diagonal - Advice Needed (Multi-page thread 1 2 3)
Read more: http://www.hometheatershack.com/foru...#ixzz3NaiKhHKz
Thanks!
post #3 of 5 Old 01-01-15, 12:05 PM Thread Starter
TXFlyGuy
Nope, no need to point! Find a white paint in matte finish and go with that. You don't have enough lumens or a need for a gray paint. And, believe it or not, that Sherwin Williams paint recommended by PJCentral may actually work for you! Given your specs, the calculator estimates 8fL which is below recommendations for a home theater. So you probably won't notice the hot spotting.
What I would do is to get a sample of whatever it is you're thinking of using and check it versus what you're currently using. If it's an improvement, re-paint the screen.
Thanks! The images in the photos are the PT-AX100U, not the new 8000U. The projector is plenty bright, even with some lighting in the room. The 8000U is way brighter than the 100U!
I'll paint up an MDF board, then see what happens. Stay tuned...
post #4 of 5 Old 01-02-15, 09:41 AM
HTS Moderator
Ask for the ''dove''
http://www.hometheatershack.com/foru...tml#post612570
Just joking about the name. The white base of B.M. should be fine.
Have a good year!
Yiannis1970 is offline
post #5 of 5 Old 01-02-15, 10:07 AM Thread Starter
TXFlyGuy
Yiannis1970 wrote: View Post
Have a good year!
Thanks for the info! Now we have two paints to test out. Will do that as soon as we get back from our Hawaii vacation...Aloha!
classic , extra , pro , satin , sherwinwilliams , white
