Rough wall to paint or frame? - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 9 Old 01-16-15, 03:55 AM Thread Starter
Currently projecting onto the living room wall with the popular Benq W1070 in eco
Screen size is currently ~130" with -1 keystone
Projector is ~4.5m from the wall
seating is 4.5-6m away
I have filled two vent holes and started sanding but the wall is anything but flat with a gentle ~5mm ripple\curve when i hold a long piece of steel across the screen\wall
The top coat of paint is a very rough surface on top of two darker coats
So down to the questions
How bad is it not to have a perfectly flat screen? it doesnt seem to bad since the ripple\curve are gradual with maybe two high points ether side of the middle before dipping back towards the edges but then the paint has a very rough surface maybe this will change and become more annoying with a smoother paint?
So im open to ideas on how best to deal with that if at all
Then the ever popular question what paint to use for somebody in Australia and should i use something different for the first coat
The living room has decent light control with blackout roller blinds but the room itself is pale with cream carpet and a shiny ceiling which the projector does a decent job of lighting up in bright scenes
I would prefer accurate color over deep blacks but obviously there nice to
Used for tv\movies and displaying photos
Cheaper the better naturally but budget is flexible if it seems worthwhile
Thanks
some picks
http://i3.photobucket.com/albums/y83...pse8743dff.jpg
prior to vent removal...
http://i3.photobucket.com/albums/y83...ps5ad18d99.jpg
dasa2 is offline
post #2 of 9 Old 01-16-15, 04:19 PM
HTS Senior Moderator
Prof.'s Avatar
The Mad Professor
Re: Rough wall to paint or frame?
You can probably get away with some slight curvature in the wall, but I wouldn't project onto a rough surface..
You would get a better result by placing a flat panel on the wall..
Just use battens top and bottom and packed up to provide a flat mounting surface..Then fix your screen to that using screws or french cleats..
Prof..
Home Theatre...the never ending story!
Prof. is offline
post #3 of 9 Old 01-16-15, 08:43 PM Thread Starter
Sanding and a few thick coats of paint should make the surface smooth
If i was to install a flat panel over it im not sure what material i can get for a screen about that size
dasa2 is offline
post #4 of 9 Old 01-17-15, 04:07 PM
Prof.'s Avatar
The Mad Professor
If the surface is slightly rough and you can just sand it and then paint, that's fine..
Are you looking at a 16:9 or 2.35:1 screen?
Prof..
Prof. is offline
post #5 of 9 Old 01-17-15, 04:40 PM Thread Starter
16:9 seems to fit the wall space fairly well
170cm is the max height i can have have the screen with the current plaster
308cm is the current width im running as shown in those pictures
im planing to stick some black felt to the wall so if i want to run 2.35:1 i can just tilt the projector down set the keystone back to 0 and extend the black felt above the screen
dasa2 is offline
post #6 of 9 Old 01-19-15, 06:01 PM
HTS Moderator
Using the keystone option is worse than a not perfect wall in my opinion. Any chance to turn it off?
Yiannis1970 is offline
post #7 of 9 Old 01-20-15, 06:14 AM Thread Starter
yes i can turn it off just the screen will be slightly narrower at the bottom its fairly hard to notice
that or i make the screen a bit smaller so its further down the wall
edit: you weren't kidding the difference between 0 and -1 keystone is huge to the sharpness
dasa2 is offline
post #8 of 9 Old 01-22-15, 09:22 AM
HTS Moderator
No, i was not...keystone is for ban for life!!
post #9 of 9 Old 01-24-15, 06:00 AM Thread Starter
after sanding for a bit it seems the wall has had 3 coats of different color paint over the years and a number of patches where things have been changed with renovations in the past
the last coat of paint ist very well stuck in some places and the sander has ripped it off in chunks and other spots it bites in due to edges\curves where the wall changes
i have grabbed 2l of cheap white flat ceiling paint but im not sure how well it will cover small holes one layer of paint deep where the sander has ripped a chunk out from the top coat of paint revealing the darker coat underneath
guess i will find out tomorrow then decide where i go from there
at the very least for now it will be better than it was till i get something better sorted
dasa2 is offline
frame , paint , rough , wall
