Simple Question That Seems To Generate Controversy - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 13 Old 06-18-08, 11:42 AM Thread Starter
gkeith
Yes I know this appears in a million places, but not in a specific discussion on the following and in a short thread that contains several but specific opinions without wandering...
I have a very near zero to zero ambient light home theater.
I have a gallon can of Behr "Ultra" Exterior Flat #4050
My projector is a DLP with good light
My screen will be 110" 16:9
Please answer with your answer and why...
Should I add any shade to the 4050 or because I'm dark, just leave it white?
dgkeith is offline
post #2 of 13 Old 06-18-08, 12:11 PM
tonyvdb's Avatar
Tony
Re: Simple Question That Seems To Generate Controversy
The use of Exterior paint inside a house is not a great idea as there are chemicals in it that over time leach out into the air and in a room this is not very good.
Adding some gray may give better contrast particularly better blacks so it wont hurt to add some. Usually the grayer the screen the better the blacks will be. but with a projector that hasn't got good light output the whites will start to suffer.
Home theater:
Living room system:
tonyvdb is offline
post #3 of 13 Old 06-18-08, 04:06 PM
Jim
I'd agree with Tony's comments on exterior paint. No reason to take a chance.
As to white vs grey...it's a matter of personal preference. If the whitest whites are your thing, go with white. If deep blacks are your thing, a grey screen helps. You have the best of both worlds with no ambient light and plenty of brightness. Some will argue that a white screen is the way to go (and there's no benefit to grey) when you have complete ambient light control. But, you do still get (at least some) reflections from the room back to the screen, and a grey will still deliver deeper blacks in a light-controlled theater. Those deeper blacks come at the cost of the whitest whites, however. You may want to look at a mix that's a light shade...maybe Cream & Sugar.
cynical2 is offline
post #4 of 13 Old 06-18-08, 07:18 PM
al_mo
Inactive
Posts: n/a
It seems to me there is another good reason to go with a darker screen in a controlled light environment: better dynamic range. What I mean by this is that if your PJ has sufficient light output in a dark room you will probably adjust it to NOT use its maximum output on a bright white screen (that's what I did). This in turn means that the number of "steps" between black and white is reduced and also the number of steps for R G and B are reduced. If you have an 8-bit projector like mine (HD70) you will not be using the full 256 levels and as a result might see some stepping effects when there is only a small change in color (like in many flesh tone images). I'm not sure this is as much of a problem with a better PJ.
Anyway I'm going to try C&S first and if it is still too bright on max output I'll go with BW.
post #5 of 13 Old 06-18-08, 10:20 PM Thread Starter
gkeith
Seems then Behr UPW 1050 with some tint is the way to go, but what tint? Below is my set up.
Home theater: Onkyo TX-SR805 AV Receiver, Polk Audio RTI Series Speakers - Fronts RTi10 - Center CSi3 - Surrounds FXi3 - Rears RTi4, Sony Play Station 3, Samsung BD-UP5000 Blue Ray / HD-DVD Player, Infocus IN32 2000 Lumen Projector HDCP Compliance Provided By HD Fury (Replaced Infocus X3 under service contract, seems comparable)
dgkeith is offline
post #6 of 13 Old 06-18-08, 11:03 PM Thread Starter
gkeith
I'm in Atlanta Metro... I have Home Depot, Lowe's, you name it.
dgkeith is offline
post #7 of 13 Old 06-19-08, 10:19 AM Thread Starter
gkeith
I am projecting on a white wall (not UPW) I think it's just plain builder grade flat a little off white... Looks real good though. I personally can see some difference between the picture quality of the IN32 and a $6000.00 Sony LCD, but not $5000.00 worth by any means. Besides the boss (wife) wanted the sound first, sooooo hence the Onkyo TX-SR805 AV Receiver & Polk Audio RTI Series Speakers.
Mostly I just want to give it a finished look and some improvement in percieved contrast.
dgkeith is offline
post #8 of 13 Old 06-19-08, 10:44 AM Thread Starter
gkeith
Let me add though that we do enjoy whiter whites, especially the boss.
dgkeith is offline
post #9 of 13 Old 06-19-08, 02:16 PM Thread Starter
gkeith
So C&S #1 is what you think.... Sure looks good... But ... If it were YOU would you go with more gray?
dgkeith is offline
post #10 of 13 Old 06-19-08, 02:26 PM Thread Starter
gkeith
Well I gotta go to ma in law's this weekend, but next weekend I'm going to go with C&S #1. I will post pics. I can always add another coat with gray if need be.
Thanks... You guys ROCK
dgkeith is offline
controversy , generate , question , simple
