Velvet tape keeps coming off Screen Goo screen - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 6 Old 10-03-09, 07:33 PM Thread Starter
Rancho
We rolled on Screen Goo digital grey and it looks fantastic! We edged it with 3 inch black velvet tape and the tape won't stick for more than 30 minutes, then sluffs off.
Any suggestions would be welcomed.
Rancho5 is offline
post #2 of 6 Old 10-03-09, 07:56 PM
Moderator Emeritus
Don
Re: Velvet tape keeps coming off Screen Goo screen
You might try using double-sided carpet tape (it might be more sticky than the velvet tape's adhesive), but you will probably end up having to use contact cement.
Harpmaker is offline
post #3 of 6 Old 10-03-09, 10:55 PM Thread Starter
Rancho
Will do. Why won't it stick to the goo screen?
Rancho5 is offline
post #4 of 6 Old 10-03-09, 11:51 PM
Moderator Emeritus
Don
Rancho5 wrote: View Post
All I can do is guess, but I would guess that either the tapes adhesive is too wimpy or it may be reacting with something in the Goo that makes it lose adhesion over time.
Another thing that will make the glue on the back of pretty much any tape soften is heat. How hot is it by your screen?
How hard did you push the tape onto the screen? You should have used a tool similar to this one (know as a "J Roller") to evenly push the back of the tape into contact with the screen.
It would also be a good idea to take some coarse sandpaper and scuff up the paint where the tape will be applied; this will create little valleys for the tape adhesive to go into.
There is an old saying in woodworking that you should NEVER depend on glue alone to hold something together, that is why there are so many different types of joints and mechanical fasteners for the carpenter/cabinet maker to choose from. Glues have gotten better over the years, but it's still a good idea not to depend on glue alone. The exception to that rule is contact cement, but only if it's used properly.
post #5 of 6 Old 11-02-09, 03:12 PM
AH Theatre's Avatar
ZMan
Hi Ranco5, how long after applying your last topcoat did you apply the Screen Flok? Did u overlap the seam where the screen and the wall meet or did you apply it to the Goo surface only?
AH Theatre is offline
post #6 of 6 Old 11-02-09, 07:01 PM Thread Starter
Rancho
It was a good few weeks after the goo screen was up that we applied the velvet tape. Just because we didn't have any, not because we waited for a specific time.
When I did the screen I overrolled quite a bit so the tape is on the entire screen, I think.
Rancho5 is offline
coming , screen , tape , velvet
