Screen material/paint recommendation? - Page 5 - Home Theater Forum and Systems - HomeTheaterShack.com
post #41 of 44 Old 10-07-12, 02:43 PM Thread Starter
Re: Screen material/paint recommendation?
I'm going to practice my spraying more until I can get a good texture. Then I'll mix up a small batch of C&S with 4oz of the tinted Valspar and 4oz of Liquitex plus appropriate water and re-spray my 2' x 3' panel for comparisons.
Once/if I master spraying, I will re-spray my screen with C&S, most likely. Unless the RS-MM-LL shows a very noticeable advantage over the C&S, it is probably too expensive to re-do my whole screen again with that one. We'll see how it goes.
curttard is offline
post #42 of 44 Old 10-08-12, 08:24 AM
HTS Moderator
ALMFamily's Avatar
Joe
I am beggining to think I should just buy a manufactured screen.....
I had considered getting a sprayer and doing C&S Ultra as well, but after reading through this thread, I am a bit more nervous about trying to do my own. Will be following along to see how it goes!
ALMFamily is offline
post #43 of 44 Old 12-12-12, 02:18 PM Thread Starter
Just to conclude this thread, here is the new thread I made comparing results: http://www.hometheatershack.com/foru...-williams.html
Plenty of people clearly get fantastic results with spraying, but personally I found it impossible to get a smooth surface that didn't exhibit noticeable graininess in a projected image; and the hassle of setup, protecting the rest of the area, and cleanup, mean I will look to roll in the future.
curttard is offline
post #44 of 44 Old 12-12-12, 04:43 PM
Moderator Emeritus
Don
curttard wrote: View Post
With our screen mixes and the OTS paint we recommend rolling shouldn't be a problem.
Harpmaker is offline
material or paint , recommendation , screen
