Help for a beginner - Black Widow Paint - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 40 Old 07-17-13, 11:44 AM Thread Starter
Hi, I was just wondering if you could help with a couple of questions regarding the black widow paint mix.
1. I accidentally bought the Dulux Wash and Wear 'Low sheen' tinted with Bermuda Beige 427-2 rather than the Wash and Wear 'Flat' . Would this significantly affect the performance?
2. Given that 'Auto Air Aluminum Fine have rendered the formula for making Black Widow™ useless', should I take the gamble that this supplier: airbrushmegastore . com (the only Australian supplier I could find) stock the older versions of the auto air aluminum fine or just start over and choose a different paint mix?
Thank you for your time
hayekian is offline
post #2 of 40 Old 07-18-13, 10:19 AM Thread Starter
Re: Help for a beginner - Black Widow Paint
Thanks for your reply . Perhaps I should just buy the AAA first and then think about the base. What base should I use for the new AAA? Do you have any idea whether it'd be available in Australia?
hayekian is offline
post #3 of 40 Old 07-19-13, 09:55 PM
Moderator Emeritus
Don
hayekian wrote: View Post
The base will be determined by whether you get the new or old AAA-F. The old requires a base paint tinted to PPG 'Bermuda Beige' while the new requires a base paint that is tinted to a neutral gray.
Harpmaker is offline
post #4 of 40 Old 07-23-13, 03:54 AM Thread Starter
I received my AAA-F today and its the new version. Specifically, what kind of neutral gray base paint should I ask for? I have a BenQ W1070 which will be ceiling mounted about 12ft from the 110-120 inch diagonal screen. The projector is in the living room which is not fully light controlled so there will be a bit of ambient light in the afternoon. I also expect to use it for 3D viewing.
hayekian is offline
post #5 of 40 Old 07-23-13, 09:32 AM Thread Starter
I think I'll go with 115 inches diagonal. As for 3D, lets just say that if a movie is available in 3D, I'll watch it in 3D so fairly important.
hayekian is offline
post #6 of 40 Old 07-23-13, 11:42 AM
HTS Moderator
If he has access to B.M., he can use it's N9 as well as white. It is called Tundra 2133-70.
http://www.hometheatershack.com/foru...tml#post616395
Yiannis1970 is offline
post #7 of 40 Old 07-23-13, 12:33 PM Thread Starter
To be honest I know absolutely nothing about paints and have no idea whether Benjamin Moore is accessible. I'll try asking. So I should just mix AAA-F with the flat white base (without tinting it grey)?
hayekian is offline
post #8 of 40 Old 07-25-13, 09:09 AM Thread Starter
would this http://www.masters.com.au/product/90...vivid-white-1l suffice as the base paint?
hayekian is offline
post #9 of 40 Old 08-06-13, 05:30 AM
Hi hayekian,
How did you go with your screen? Very interested to know how you went with just adding the AAA+f to the Dulux white!!
bonkers20 is offline
post #10 of 40 Old 08-06-13, 08:19 AM Thread Starter
Hey, well according to the guy I spoke to at Bunnings, Dulux don't make the flat white version anymore so I had to order it online. I received my order yesterday but they gave me the Matt instead so now I'm waiting for them to exchange it. I'll keep you updated
hayekian is offline
auto air aluminum , beginner , black , black widow , paint , widow
