Paint recommendation for Optoma HD25e (light cannon) projector. - Page 7 - Home Theater Forum and Systems - HomeTheaterShack.com
post #61 of 69 Old 05-08-14, 01:50 PM
stephen
Re: Paint recommendation for Optoma HD25e (light cannon) projector.
So ok firstly did you put those contrast / brightness settings in while being in the dark or not plus leaving brilliant color on 1 tints the whole of the screen a browny/pinky shade.
Have you tried YUV color space as yet?...............My pj is only calibrated using a calibration disc S/M.
mojogoes is offline
post #62 of 69 Old 05-08-14, 07:50 PM
mojogoes wrote: View Post
If select YUV in color space, the whole picture turns blue.
My system is an HTPC (hdmi-out from an Nvidia Card).
FabioMC is offline
post #63 of 69 Old 05-10-14, 05:43 AM
stephen
FabioMC wrote: View Post
Ok! So the YUV setting is only for playing movies from a blu ray player!! If! I even watch tv with pj or pc the YUV setting is no good and has to be switched back to either auto / 0-225 / 16-235 ............But YUV for bd player use is a much better setting as with only a calibration disc like spears and munsil plus the blue red and green filters , you can get the picture quality and colours to be much more natural looking plus the blacks are darker too!!!
mojogoes is offline
post #64 of 69 Old 05-10-14, 08:39 AM
stephen
I have cms settings that if you were using a bd player would probably give you the best picture that you have seen from a hd25e even if you were using a matt white or grey BW painted wall or brightness of room / screen!! As they have been used on both with small tweaks between either.
mojogoes is offline
post #65 of 69 Old 05-28-14, 11:12 AM
stephen
Well just a little update about settings with the newly painted BW manual pulldown screen! Which prompted me to delve into a more in depth look at calibration of my hd25e!!
Calibration of my pj with the S&M hd disc on my newly painted BW screen has been very fruitful!! Especially when I then added to this some settings and adjustment to the isf picture perfect on my onkyo receiver which made it possible to get very very close to the S&M standard contrast and to the red blue and green contrast box,s which before hand seemed very difficult to be able to get spot on.................but now voilą the picture looks extremely natural.
mojogoes is offline
post #66 of 69 Old 05-28-14, 08:33 PM
Moderator Emeritus
Don
Cool!
Properly calibrating a projection system can make a huge difference in the projected image.
Harpmaker is offline
post #67 of 69 Old 06-08-14, 03:09 PM
stephen
Hi There mojogoes.
I have the same specs and I'm thinking about using the same BW combination.
What happened to your 3D brightness? Still fine or got too dark ?
Thank U.
Hi mech and sorry for the very long delay !! The 3d picture / brightness is fine and after going to some lengths to calibrate me pj for the darker grey steel one the 3d looked fantastic especially on the spear and munsil hd disc 3d demo section........................its quite surprising at how much brightness / lum you actually need especially when used at night even in a lightly coloured painted room.
mojogoes is offline
post #68 of 69 Old 11-22-15, 10:11 AM
New Member
Patrick
This one is for clark17 (if he is still around! . I'm basically looking for the exact same setup as you in terms of projector and paint. The paint situation is settled as I have followed the whole thread from beginning to end. However, as for calibrating the projector, I know you gave your calibration specs when you had the BW paint on, but not for when you put on the Valspar. I was wondering if I could get an update on your specs.
Thank you so much and thanks for asking all those questions which I now do not have to ask .
Pat.
Last edited by ICthelight; 11-22-15 at 10:13 AM. Reason: Edited username of the person I was trying to reach
ICthelight is offline
post #69 of 69 Old 12-04-15, 11:06 AM
New Member
Patrick
Anybody else?
cannon , hd25e , light , optoma , paint , projector , recommendation
