-   DIY Screens (https://www.hometheatershack.com/forums/diy-screens/)
-   -   painting wall/screen question (https://www.hometheatershack.com/forums/diy-screens/163033-painting-wall-screen-question.html)
ravnis 12-28-16 10:00 PM
Extreme newbie question here. Will there be any long term bad effects if I paint primer on my wall to use as a screen and then repaint it later when I learn enough and acquire a good paint/paint mix for the actual screen? I'm thinking of rolling it on. 1/4" nap seems to be a recommended roller. I'm not opposed to sanding and have sanded some of the texture off to find the wall is some kind of fabric/knit type pattern that I guess they just painted over. I'm not sure what material the wall is other than it's not a Sheetrock unless they started covering it with cloth.
I think I would spray the final coat when I get to that point and can keep from spraying onto furniture. I have a wagner airless paint sprayer, but I've only used it to paint a barn and the finish was not demanding at all.
ravnis 12-28-16 10:09 PM
Re: painting wall/screen question
FYI. I'm looking at Kilz premium primer.
DqMcClain 12-29-16 06:32 PM
Is the fabric covering the entire surface of the wall in question, or is it just strips? Often, the seams in drywall are taped with what looks like an open mesh tape, since this helps the spackle stick and hold a shape.
As for priming and projecting onto the primer until you decide on a top coat, that shouldn't matter. In fact, it's entirely possible that you'll be just fine with the Kilz primer and decide not to put a top coat on at all.
ravnis 12-29-16 07:43 PM
Thank you so much for your response.
The whole panel is covered with the mesh/cloth. Nearest I can find with googling is that it's some kind of acoustic panel. Though it's not quite a perfect match to that either. It's a modular home wall, so construction is probably as cheap as they could get away with I'm sure. The fabric acoustic panels are expensive, so that puzzles me. I did buy used and the original owner was an avid Diy'er and made many modifications elsewhere.
I did go ahead and paint the wall with the primer after I got off work with Kilz premium primer. I had wondered what Hot spotting was that I had read about happened with too glossy a paint. I watched a movie after freshly painting the wall and saw really quickly what it was. I could literally see it fade away as the paint dried. This had the added bonus of when asked what I did last night of being able to say "watched paint dry" :grin2:
DqMcClain 12-30-16 06:14 PM
I've spent a lot of time watching paint dry...
I don't really have any of those issues, as my screen is a DIY 85" where I used 1/4" melamine-coated MDF. Turns out, the melamine surface is just about the right amount of reflective and a neutral enough shade of white that it satisfies my needs while being extremely inexpensive.
I'm not certain how neutral the Kilz primer is... but if it looks good to you, that's all that matters. I just read through an article on Projector Central about DIY paint screens. They apparently got good results with Sherwin Williams ProClassic Smooth Enamel in Satin, and using the base white with no tint. Measured against a Studiotek 100, they claim image resolution is similar, with a 1.1 Gain, and slightly better black levels. I imagine "your mileage may very" applies here.
Yiannis1970 01-04-17 04:58 AM
Can't remember right now if i have seen Kilz's measurement, but, considering the fact that is a white primer (white ''color'' is the most forgiving in terms of neutrality), i believe that it will be quite neutral (from 6300K-6800K). So, i see no problem using it as a main screen. They were claims in the past that many manufacturers were using just primed walls as their reference screen to test the units.
ravnis 01-04-17 01:05 PM
Thanks for the info. The primed white wall is doing well. Still see some of the texture behind it. I'm on my 4th coat and letting it dry for a couple of days between coats to give it a chance to cure. I'm no painter, but the image improves a little with each more coat. The missus is happy and that's the main thing. There is some "blurring on the image , I think it's cause by the texture. Going to look around for MDF with melamine coating as that sounds like it may be a good alternative. Can more than one 8 x 4 sheet be merged without a seam? My image is currently 96" x 54" , so a single sheet wont cover it all.
Yiannis1970 01-05-17 04:18 AM
Don't think that blur thing is caused by primer or your wall. Can you give us a little more info about your projector? (brand, model, lamp hours)
Zakk 01-06-17 02:56 AM
Why not buy a screen? A wall will never compare unless you spend very significant time making it perfect and then buy very specialized screen paint that is likely more expensive for a gallon than the cost of a screen like Silver Ticket.
ravnis 01-06-17 04:46 PM
It's a entry level (at least for me) projector. Brand was sold as generic and LED 86W is the only identifier I've found on it. I've been searching for compatible active shutter glasses and I've found that the LED86 is not a good distinguishing mark.
My son discovered that some of the settings I had adjusted to electronically reduce the screen size had caused some of the blur and my 20 something son managed to show me up in setup of this projector.
I've really been keeping track of the cost factor. I'm really thinking I'm going to live with the paint wall and finish out the gallon of paint for now. I think I'll give the silver ticket lot more consideration before I spend anymore. It's not a waste though as the wall was needing fresh paint anyways.
Thank you all for the help.
