-   DIY Screens (https://www.hometheatershack.com/forums/diy-screens/)
-   -   AT Screen vibration (https://www.hometheatershack.com/forums/diy-screens/81962-screen-vibration.html)
f0zz 06-09-14 04:27 PM
AT Screen vibration
Im currently researching DIY AT screen and would like to give it a shot. My primary concern regarding the screen is my subwoofers. I have four 10" subwoofers built into the front wall where the screen is placed. The subwoofers are on either side of the screen right now, but if I build a new screen, it would be much larger and would cover the subwoofers.
How much physical vibration should I notice through the screen if any? Obviously, none if I can help it.
The subwoofers would be pretty close to the screen (2"away best guess).
orion 06-13-14 01:19 PM
Re: AT Screen vibration
I guess it would depend on how tight the screen is. I asked the same question a year ago and was assured by someone that it wouldn't be an issue. I have 3 M1's from Chase ( I know its not the same as 10 subs) right behind the screen and it doesn't cause issues
mr_tv 06-24-14 07:43 PM
i have a infinate baffle speaker manifold just to lower right of screen. I have not had any issues with screen vibrations or ripples during a movie.
ellisr63 06-24-14 09:22 PM
I will let you know how mine goes in a couple of weeks... I have the Danley DTS-10 firing up in front of the screen, about 6" away.
orion 06-24-14 09:45 PM
Well if the Danley doesn't move the screen I do not think most of us would have an issue. Keep us updated in case my wife lets me change things up someday
