DIY 2 way Synergy speakers - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
 12Likes
post #11 of 41 Old 11-22-16, 10:39 AM Thread Starter
ellisr63's Avatar
Ron
Re: DIY 2 way Synergy speakers
Tonto wrote: View Post
My guess would be no.
Sames as my guess, but my friend helping me thinks there will be an angle cut... We will see this weekend.
My Home Living room Theater
Samsung 65" FP, Yamaha CX-A5100, Xilica XP4080, (4) Klipsch RP160MS, (4) JBL 8340As, (2) Yamaha P2500s amps, PS3, XBox One, (1) Asus mini pc, (2) Furman Power Conditioners, Darbee Darcet, and a Project RPM 1.5 Carbon turntable..
ellisr63 is offline
post #12 of 41 Old 11-27-16, 06:50 PM Thread Starter
ellisr63's Avatar
Ron
Post #2 has updated pics of the progress. We also found out that a straight cut will not work when cutting the angled top and bottom of the horn. Next weekend we hope to get the angles down.
ellisr63 is offline
post #13 of 41 Old 11-28-16, 03:28 PM
HTS Senior Moderator
chrapladm's Avatar
Papi
Thanks for adding this thread to your HT room thread. Never knew about this build. Looks great so far. Still looking at doing a 3 way SH but your dimensions are pretty close to what I wanted to do.
ellisr63 likes this.
"Music is the space between the notes"
“[T]o talk well and eloquently is a very great art, but that an equally great one is to know the right moment to stop.”
chrapladm is offline
post #14 of 41 Old 12-12-16, 11:51 AM Thread Starter
ellisr63's Avatar
Ron
Sunday we worked on getting the last 2 sides (top and bottom) of the 1st horn completed...it took us 6 hours to get it done. We did though get 2 extra done so we won't have to deal with the angles for the next speaker horn. This was the part we were both dreading...getting the multiple angles right, and it proved to be difficult, but we prevailed.
Next we will be trimming the horn flush with the cabinet, and then make the extensions for the horns (different angle).
ellisr63 is offline
post #15 of 41 Old 12-12-16, 03:31 PM Thread Starter
ellisr63's Avatar
Ron
Any suggestions as to what material to use for a smooth horn transition? I am hearing Bondo, Wood Filler, and Modeling clay, but i don't know which is best to use.
ellisr63 is offline
post #16 of 41 Old 12-12-16, 03:55 PM
willis7469's Avatar
Fiberglass is popular in custom car audio. The learning curve may be a little steeper than the others but I'm pretty sure it will outlast any of the others. Bondo dries and cracks, modeling clay is about the same and wood filler would probably be the same.
Sent from my iPhone using Tapatalk
willis7469 is online now
post #17 of 41 Old 12-18-16, 01:27 PM Thread Starter
ellisr63's Avatar
Ron
I wish I knew someone that could draw this up in CAD for me to take to a local CNC place to get the next pair cutup. This way it would be perfect, and we wouldn't have the problem with using Bondo, fiberglass or any of these problems with modeling.
willis7469 likes this.
ellisr63 is offline
post #18 of 41 Old 12-18-16, 01:28 PM Thread Starter
ellisr63's Avatar
Ron
I have 4 more woofers on the way now.
ellisr63 is offline
post #19 of 41 Old 01-14-17, 06:54 PM Thread Starter
ellisr63's Avatar
Ron
Today we got it to the point that we only need the following:
1: fill holes with wood putty
2: mount speaker wire jacks, and wire speakers up
3: sand speaker cabinet
4: install weatherstripping for sealing cabinet
Hopefully next time we will be to fire it up to see how the compression driver sounds, and then also how the woofers sound. At that time it might be ready to take home, and set up the crossover...for some real serious listening.
ellisr63 is offline
post #20 of 41 Old 01-14-17, 06:59 PM
chrapladm's Avatar
Papi
Nice I forgot about this build. I was looking at building a pair of SH's to see which I will like. I have three JBL 1.5 CD's and will look at trying a AMT SH also. Looks good so far.
diy , speakers , synergy
