RB-Kit in the ceiling - Surrounds - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 18 Old 04-10-09, 04:11 AM Thread Starter
keelay's Avatar
Kyle
Here's another of my build threads.
I bought a set of 4 RB-Kit speakers from Madisound. ...Enough to complete my surround speakers. I wanted to test these kits out and see whether I would be pleased with them and whether they would fit in with my Natalie P's mains.
This is my build thread for building and mounting the enclosures in the ceiling.
After modeling the woofer, a 0.5 CF box optimized the bass response with a port tuned to 48Hz. I wanted to put these guys in the ceiling with minimal presentation in the room. That meant that most of the box would have to go in the ceiling.
keelay is offline
post #2 of 18 Old 04-10-09, 04:13 AM Thread Starter
keelay's Avatar
Kyle
Re: RB-Kit in the ceiling - Surrounds
The box is designed to be 22.5 inches long, which is perfect spacing between trusses in the ceiling. I plan to mount the speaker to the trusses and have the angled part of the speaker poke through the drywall along with the bass port.
-Kyle
keelay is offline
post #3 of 18 Old 04-10-09, 04:15 AM Thread Starter
keelay's Avatar
Kyle
So here I am planning for the bass port. I glued a bunch of blocks to gether so I could drill through it for the port. The other little square with the hole in it glued on was an abandoned plan for adding a port, but it was already glued on.
keelay is offline
post #4 of 18 Old 04-10-09, 04:17 AM Thread Starter
keelay's Avatar
Kyle
So here I am getting ready to and drilling the hole for the bass port. This port is 1.5" wide and 2.75 inches long It is all wood and this method was very easy to do. I think this was the easiest method for installing a bass port in a box that I have tried.
keelay is offline
post #5 of 18 Old 04-10-09, 04:21 AM Thread Starter
keelay's Avatar
Kyle
So here are some more photos of the flaring processes. I think you can see the router bit I used to flare the inside and outside of the port. It makes flaring trivial.
Kyle
keelay is offline
post #6 of 18 Old 04-10-09, 04:25 AM
jeremy7's Avatar
jeremy
great idea for the port. I never would have thought of that
jeremy7 is offline
post #7 of 18 Old 04-22-09, 11:23 AM
DerekG
I can't wait to see how this goes. I was thinking of doing the same thing to pair up with my infinity beta 20s.
dgilme is offline
post #8 of 18 Old 04-22-09, 02:35 PM
filtor1's Avatar
Chris
This is an amazing idea! I was wondering if you could post up an approximate cost of the entire build. I have been pondering how to get the best placement while getting the rears off the ground. As the rears I have now are rear ported, this was never an option. But now I see the error in my thinking. I never considered building similar units to my BA CR85 mains and using the other two elsewhere.
Good stuff. I will definitely be following this build.
filtor1 is offline
post #9 of 18 Old 04-22-09, 03:52 PM
Brian
Im loving this creativity. Keep up the good work!
My HT equipment
bonehead848 is offline
post #10 of 18 Old 04-25-09, 07:40 PM Thread Starter
keelay's Avatar
Kyle
filtor1 wrote: View Post
The cost:
RB-Kit $59.00 x 2 + shipping $15.00 = $133 (Madisound.com)
4'x8' Sheet of MDF = $27 (@Lowes)
1 Large bottle of wood Glue $4 (Walmart)
Speaker Wire $10
Misc other stuff (insulation, a few screws, etc laying around) $0
Total $174 for 4 Vifa rear surrounds. (So far I've only posted the build for the 2 rear channels)
NOTE: I'm adding some pics for the other two surround speakers now...
keelay is offline
bass port , ceiling , diy speakers , madisound , natalie p surrounds , rb-kit
