Last dumb question, (maybe). - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 7 Old 12-22-09, 11:52 PM Thread Starter
cavedog's Avatar
Garry
Talking Last dumb question, (maybe).
Is the soldering the splices to extend two speaker wires prudent?
cavedog is offline
post #2 of 7 Old 12-23-09, 06:52 AM
Mike P.'s Avatar
Mike
Re: Last dumb question, (maybe).
Not a problem.
We're all in this together!
Mike P. is offline
post #3 of 7 Old 12-23-09, 08:26 AM
tcarcio's Avatar
TC
There are no dumb questions: If you don't ask then you will never know the answers....
tcarcio is offline
post #4 of 7 Old 12-23-09, 09:06 AM
xyrium's Avatar
Paul
Some argue that gas tight joints are better (and certainly simpler) than solder joints. I myself, prefer solder joints for strength. However, for simply extending some speaker wires in the room, I'd say that some butt connectors may suit you just as well. Just slide some heat shrink over the wire before crimping the butt connector, then heat the heatshrink over the connector for a polished look.
xyrium is offline
post #5 of 7 Old 12-23-09, 09:18 AM
Plain ole user
lcaillo's Avatar
Tech Guru
There is nothing wrong with soldering splices. However you make a splice, you want to be careful not to allow any shorting of the conductors. It is best to offset the splices on the two conductors so that they are not adjacent. When soldering make sure that there are smooth results with no sharp tips that can poke though insulators to the other conductor.
There are dumb questions, BTW, and I am sure this is true becuase I have asked a few myself. I don't think that this is one of them.
lcaillo is offline
post #6 of 7 Old 12-23-09, 02:40 PM
Paul P
+1 on the heat shrink tubing, after soldering. Thin tubing on the individual wires
and then wider tubing over the whole thing. I've found the ultimate shrinker :
BernzOmatic Flexible Utility Lighter
This thing produces a small pointed blue flame like a blow torch. You have to
move quickly but it works great.
Paul P
Paul P is offline
post #7 of 7 Old 12-24-09, 06:42 AM
Plain ole user
lcaillo's Avatar
Tech Guru
More common than dumb questions are dumb mistakes. Remember to put the shrink wrap tubing on BEFORE soldering the joint. Not that I have ever forgotten to do that, but I have heard of the problem before.
lcaillo is offline
(maybe). , dumb , question
