DIY Speaker and Subwoofer Enclosure Tools - Page 3 - Home Theater Forum and Systems - HomeTheaterShack.com
post #21 of 40 Old 02-17-10, 01:10 AM
Mike
Re: DIY Speaker and Subwoofer Enclosure Tools
Best saw guide system I have used:
http://eurekazone.com/products/detail/sgs.html
I have the 114" system. Not cheap when compared to the simple straightedges, but really cheap when compared to the Dewalt, Makita, or Festool tracksaws, which is a more accurate comparison.
I can split a 0.5 mm pencil mark every time, though I do have to put them in the right places. I cut all of my sheet goods with this system (and I have a very nice tablesaw)
No affiliation other than being a very happy customer.
littlemike is offline
post #22 of 40 Old 09-18-10, 04:45 AM
alaok's Avatar
As broad-based tools for an earnest diyer, making enclosure will concern with a lot of things: design tools, woodworking tools...... And I think, some accoustics measurement tools are needed also, use them to tune the enclosure.
alaok is offline
post #23 of 40 Old 02-20-11, 06:42 PM
Danny
This is something I cobbled to gether for smallish to to large circle cutting. The wooden pieces are 1/2 and 3/4 sheet stock glued together. The top (3/4" piece) has a 1/4" slot centered lengthwise which accepts the double locking knobs. The flip side has a slot centered to accept the flat bar stock.
I through drilled and tapped 4 four 1/4-20 holes in the bar stock. The threaded holes can accept either a 1/4" pivot pin form the bottom or the two locking knobs from the top. The nice thing is that you can move the pivot pin to any hole in the bar allowing one to cut holes from about 3" to to over 60 inches. I also drilled and installed t-nuts on the end of the jig to accept an extension for cutting any size arc. Really works great.
djdiaz is offline
post #24 of 40 Old 02-20-11, 07:47 PM
bambino's Avatar
bambino
A good saw, Circular with a straight edge or better yet a fine tuned tablesaw.
Router with good variety of bits (i prefer freud) also a circle jig.
2 cordless drills
clamps, clamps and more clamps
Did i mention clamps?
bambino is offline
post #25 of 40 Old 02-21-11, 08:03 AM
HTS Moderator Emeritus
Anthony's Avatar
Anthony
I don't think you mentioned clamps. Do I need more clamps?
I have about 30, and sometimes it still doesn't seem like enough (I always need one a little bit longer or smaller than what's left on the rack)
Anthony is offline
post #26 of 40 Old 02-21-11, 04:26 PM
bambino's Avatar
bambino
Anthony wrote: View Post
Oh i allmost forgot you need lots and lots and lots of clamps.
bambino is offline
post #27 of 40 Old 12-10-11, 10:03 AM
So what do y'all use to draw/lay out large circles? I can't seem to find a compass larger than a 12" circle.
Tom
tshifrin is offline
post #28 of 40 Old 12-10-11, 04:27 PM
Tom
One way is to place a nail in the center of the circle and tie a 6" wire to the nail and a pencil.
CarolinaNomad is offline
post #29 of 40 Old 12-12-11, 09:18 AM
Anthony's Avatar
Anthony
I do wire/string for drawing large circles.
Rockler.com (and others) sell larger trammel arms for bigger circle routing, but you can easily make your own with a scrap of plywood. Drill for a pivot on one end and use your router base to co-drill the mounting holes on the other. You can make any size you want, it just usually isn't adjustable (at least not with some work at it).
Anthony is offline
post #30 of 40 Old 01-31-12, 09:31 PM
Oktyabr's Avatar
Titebond III Ultimate Wood Glue is the bomb! WAY stronger than the wood you are gluing. Well... once you have collected all the clamps from every garage sale in town you need something for the clamps to hold, right?
Oktyabr is offline
diy , enclosure , speaker , subwoofer , tools
