Synergy Horns-Dayton and PRV..... - Page 4 - Home Theater Forum and Systems - HomeTheaterShack.com
 3Likes
post #31 of 33 Old 06-11-17, 09:59 AM
Re: Synergy Horns-Dayton and PRV.....
grats for the project, it looks really cool
LORDSANSUI is offline
post #32 of 33 Old 06-13-17, 02:41 PM
ellisr63's Avatar
Ron
SpeakerScott wrote: View Post
I don't have a lot of time for a lengthy reply on the workings of a Synergy Horn, but a two way "Synergy" design is not possible given the driver sizes you've listed. You would not be able to optimally tap into the flare rate at the correct points in a conical or quadratic horn expansion. If you did make a two way, there would be no way to get down to 40Hz for similar reasons. In addition the driver entrances (if optimally tapped into the horn) would not meet the 1/4 wavelength requirement between entrances at the crossover point for a time domain accurate speaker.
I suspect you could make an offset driver co-entrant horn with 2 15's and 1 compression driver, but it would not be a Synergy design, not even close...the physics prevent it.
I strongly suggest that you re-read the synergy patents and Tom's many posts on how the designs work, the high level information is out there, and available.
Sincerely,
Scott
Thanks Scott, I have decided to stick with the 2 way and go the way Chris on the Klipsch Forums has done his...as he has proven it does work as a 2 way. Danley has 2 way versions too...SH95HO is a 2 way Synergy horn.
Sent from my SM-T550 using Tapatalk
My Home Living room Theater
Samsung 65" FP, Yamaha CX-A5100, Xilica XP4080, (4) Klipsch RP160MS, (4) JBL 8340As, (2) Yamaha P2500s amps, PS3, XBox One, (1) Asus mini pc, (2) Furman Power Conditioners, Darbee Darcet, and a Project RPM 1.5 Carbon turntable..
ellisr63 is offline
post #33 of 33 Old 08-31-18, 01:29 PM
A little resurrection here.... Are these still doing well for you? Is there anything you would change or have you made any updates?
I'm about to try these out but will probably use the Dayton Audio DSP for xover duties. Any suggestions about xover points, slopes, delays, etc.? What's the sensitivity for these and any idea on max output? I'll probably try these for P.A. use to see how they'll work...
BoomShack is offline
constant directivity , dayton audio , hornsdayton , prv , synergy
