-   DIY Speakers (https://www.hometheatershack.com/forums/diy-speakers/)
-   -   Madisound box question (https://www.hometheatershack.com/forums/diy-speakers/29732-madisound-box-question.html)
Voodoo Rufus 06-06-10 12:10 PM
I was considering using some of the Madisound boxes for my Exodus 2641/LCR/61 projects. One thing that was bothering me with them is the small corner round-over. Has anyone modified the front baffles with a larger round-over and then repainted them?
JCD 06-06-10 03:01 PM
Re: Madisound box question
I haven't, but I might be a little worried how the routing would go when you already have the boxed veneered.
If you're worried about the edge diffraction, you could us these:
http://www.madisound.com/catalog/ima...oduct/RING.jpg
Just $2 at Madisound.
Voodoo Rufus 06-06-10 03:06 PM
The baffles are painted while the sides are veneered. Which is why I was thinking of it.
I suppose another question is, should I worry about edge diffraction?
JCD 06-06-10 03:35 PM
I think it's worth the effort to minimize the edge diffraction of a speaker -- particularly when you're going to build the box yourself. There is a utility somewhere out there that will tell you how much diffraction you have with a particular box, placement of driver, and size of driver. It's amazing how much different a 1/2" can make.
However, I'd probably NOT modify the boxes from Madisound. I think it kind of defeats the purpose of buy a premade box and even though the baffle is the only part that is painted. Also, to get a roundover that is going to REALLY do the job is going to require eating into the sides as well i believe.
Again, I'd use that felt ring -- especially if you're going to have some sort of grill in place.
lsiberian 06-06-10 09:11 PM
If you have a router and a saw you can easily build the boxes yourself. Then you use quarter round and pre-veneered wood to build a box you can simply finish.
I don't get the felt rings?
Voodoo Rufus 06-06-10 09:12 PM
I've built boxes twice before, but they were both painted. My GR AV-1s came out pretty well, but my FR125s look much better.
Lack of tools is the limiting factor, but I'll get some eventually.
lsiberian 06-06-10 09:28 PM
Voodoo Rufus wrote: (Post 268624)
I think as long as you brace and line well you will have a great speaker. I'd not worry about the roundover
JCD 06-08-10 08:29 PM
lsiberian wrote: (Post 268623)
It's supposed to help with edge diffraction
