car sub and box help - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 8 Old 01-12-15, 10:15 AM Thread Starter
I been looking at using a car sub for ht use building a sono tube box and looking to go ported with it and use just one sub. heres what ones I been looking at
http://www.audiosavings.com/products...4/G215-44.aspx
http://www.sonicelectronix.com/item_...PI-BI.154.html
http://www.sonicelectronix.com/item_...k-CW2-154.html
http://www.sonicelectronix.com/item_...C-W3013PS.html
http://www.sonicelectronix.com/item_...nce-1260W.html
out of these what would work best and any others that you guys would recommend looking to stay under $70 if I could the room size is 15' 8 inch wide 11' deep and 8' 5inch high and don't laugh
allisman42 is offline
post #2 of 8 Old 01-12-15, 07:04 PM
HTS Senior Moderator
chrapladm's Avatar
Papi
Re: car sub and box help
How much room do you have for this subwoofer?
Most of these will be ok but nothing special. Porting most of these subwoofers will require a large cabinet. There are some TH's that can use the 1260 and produce very good results. So if you have the room and very little budget a horned subwoofer would be your best bet for HT. If not then large ported would be the next step.
"Music is the space between the notes"
[T]o talk well and eloquently is a very great art, but that an equally great one is to know the right moment to stop.
chrapladm is offline
post #3 of 8 Old 01-13-15, 05:40 AM Thread Starter
I think a 12 will work best for me so I got looking at a ton of different 12's and after all I think the infinity 1260 will work best for me. now I need a box size and I plan. looking now to do a horn or ported
heres specs of the subwoofer
THIELE-SMALL PARAMETERS
VOICE COIL DCRESISTANCE: REVC (OHMS) . . . . . . 3.59
VOICE COIL INDUCTANCE @ 1KHZ: LEVC (MH) . . . . . . . 2.89
DRIVER RADIATING AREA: SD (IN2) . . . . . . . . 82.30
SD (M2) . . . . . . . 531.00
MOTOR FORCE FACTOR: BL (TM) . . . . . . . . 16.90
COMPLIANCE VOLUME: VAS (FT3) . . . . . . . . 2.92
VAS (LITERS) . . . . . 82.96
SUSPENSION COMPLIANCE: CMS (μM/N) . . . . 206.00
MOVING MASS, AIR LOAD: MMS (GRAMS). . . . 222.00
MOVING MASS, DIAPHRAGM: MMD (GRAMS) . . . 214.00
FREE-AIR RESONANCE: FS (HZ) . . . . . . . . 23.50
MECHANICAL Q: QMS . . . . . . . . . . . 6.99
ELECTRICAL Q: QES . . . . . . . . . . . 0.41
TOTAL Q: QTS . . . . . . . . . . . . 0.39
MAGNETIC-GAP HEIGHT: HAG (IN) . . . . . . . . 0.314
HAG (MM) . . . . . . . . 8.00
VC (IN) .. . . . . . . . . 1.34
HVC (MM) . . . . . . . . . . 34
MAXIMUM EXCURSION: XMAX (IN) . . . . . . . 0.512
XMAX (MM) . . . . . . 13.00
post #4 of 8 Old 01-19-15, 06:07 AM Thread Starter
any help with the box size for the infinity.
post #5 of 8 Old 01-19-15, 07:35 AM
chrapladm's Avatar
Papi
For this 12 you will need a big box to dig low. Something like 5cuft ported at 20hz for movies. Only take about 300watts to hit Xmax with a 18hz 3rd order Hpass.
post #6 of 8 Old 01-19-15, 05:39 PM Thread Starter
ok thanks
post #7 of 8 Old 01-20-15, 04:39 PM
morca's Avatar
morca
what kind of port are u building? A tube?
Simulation is no substitute for thought.
morca is offline
post #8 of 8 Old 01-21-15, 03:24 AM Thread Starter
Was just just gonna use a aero port but was gonna build box out of sono tube.
box , car
