AE AV15-H Ported Box Size? - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 4 Old 03-06-15, 05:49 PM Thread Starter
sbx
I have a couple of these drivers and was going to put them in to sealed enclosures, I used Unibox and with a 1000w input in a 1.98cu ft (56Lt) box it gave a QTC of 0.547 and reached xmax at 10Hz.
The room I am going to be using will be approx 2000 cu ft. I started wondering if it would be better to go for a ported design, if so, has anyone any ideas on what size enclosure, and what size/length port would suit these drivers?
Thanks
sbx is offline
post #2 of 4 Old 03-21-15, 04:38 PM
HTS Senior Moderator
fusseli's Avatar
Re: AE AV15-H Ported Box Size?
You would have to post the full TS parameters of the drivers so they could be modeled.
fusseli is offline
post #3 of 4 Old 03-21-15, 04:58 PM Thread Starter
sbx
Here are the ts details;
AV15-H
Fs: 22Hz
Qms: 4.86
Vas: 197L
Cms: .22mm/N
Mms: 235g
Rms: 6.7kg/s
Xmax: 23mm
Xmech: 32mm
Sd: 794dqcm
Vd p-p 3.67L
Qes: .29
Re: 2.7ohm
Le: 2.8mH
z: 4ohm
Bl: 17.6Tm
Pe: 1000W
Qts: .27
1wSPL: 90.7dB
2.83V: 95.5dB
Thanks
sbx is offline
post #4 of 4 Old 05-09-15, 10:10 AM
SBX:
Check out the ported build sections here.
You can also go to the forum at aespeakers.com for feedback.
Muser is offline
ae , av15h , box , ported , size
