Internal wiring gauge? - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 13 Old 01-25-16, 09:46 AM
tonyvdb's Avatar
Tony
Re: Internal wiring gauge?
It eliminates the chance of it coming loose. So it can.
Home theater:
Living room system:
tonyvdb is offline
post #12 of 13 Old 01-25-16, 10:01 AM Thread Starter
nick
How about assuming there both properly connected? Im thinking maybe I should use all 4 pins on the SpeakOn whether I use the disconnects or solder the wire to the pins, that will give me the lowest resistance connection compared to using two of the pins right? Then I can just bridge the two positives and two negitives to get pack to two wires to connect to the driver.
nickwin is offline
post #13 of 13 Old 01-25-16, 03:34 PM
tonyvdb's Avatar
Tony
It's your choice, a bit overkill but won't hurt
Home theater:
Living room system:
tonyvdb is offline
gauge , internal , wiring
