Downloadable WinISD Pro Files - Page 10 - Home Theater Forum and Systems - HomeTheaterShack.com
post #91 of 241 Old 12-17-12, 05:32 AM
Moonfly's Avatar
Re: Downloadable WinISD Pro Files
Just an update. I copied the driver and project folders across to the other partition and did an un-install. Then used CC cleaner to get rid of anything left over. Reinstalled the programme and all is well again I have also wiped the driver folder clean and only copied over the files I use the most, so my driver directory is now much tidier and I dont have to scroll through hundreds of files to get to the ones I want, probably less than 50 now. The originals are still all saved on the other drive for future reference.
Cheers guys.
Moonfly is offline
post #92 of 241 Old 12-19-12, 11:31 AM
Moonfly's Avatar
Fi look to have updated their X drivers. Justr looking at the specs here:
http://bladeice.com/index.php/produc...audio/x-series
I was just plugging the TSP's into WinISD but it doesnt seems to like the data. Can anyone else take a look and confirm for me, wouldnt mind a second opinion.
Moonfly is offline
post #93 of 241 Old 12-19-12, 10:34 PM
GPM
GPM's Avatar
GM
I only checked the 10" with the well proven theoretically 'perfect' math I use, so Vas is a little low based on Sd, Fs, Mms, but the SoS test conditions Vs the default values I use can account for enough of the variance.
BL Vs Re OTOH is a bit confusing, i.e. a 14.01 BL is close enough only if there’s a single 2.8 ohm Re VC or dual 1.4 ohm wired in series; whereas getting a close enough 19.81 BL requires dual 2.8 ohm VCs wired in series.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
GPM is offline
post #94 of 241 Old 12-20-12, 07:32 AM
Moonfly's Avatar
The issue Im seeing is the Q values are all out. I'm looking specifically at the X15. If I enter mms and fs (resulting in cms be calc'd), then sd, bl, and re, Qes is estimated, and its out by a fair margin. Then if you input Qms, Qts is out by miles. If you input Qts so as to auto calc Qms, that figure ends up even further out (results in a - figure). This is an obvious issue as it end up with an incorrect cabinet volume calculation.
Thoughts?
Moonfly is offline
post #95 of 241 Old 12-20-12, 08:33 AM Thread Starter
Mike P.'s Avatar
Mike
My numbers match Fi almost spot on. Vas is out by 2 liters. Here's the Driver file for the X15 D2.
Fi X15.wdr
We're all in this together!
Mike P. is offline
post #96 of 241 Old 12-20-12, 08:58 AM
Moonfly's Avatar
Thats strange, I wonder if its still playin up for me for some reason.
Moonfly is offline
post #97 of 241 Old 12-20-12, 08:59 AM Thread Starter
Mike P.'s Avatar
Mike
Upload your file so I can have a look.
Mike P. is offline
post #98 of 241 Old 12-20-12, 11:47 AM
Moonfly's Avatar
I didnt dave a driver file due to the inconsistencies. I have attached a screen cap of the data input screen, you can see the input data and the calculated data, and you can see the discrepancies. Maybe Im missing something obvious, it happens from time to time.
Moonfly is offline
post #99 of 241 Old 12-20-12, 12:30 PM
Moonfly's Avatar
Qms was ipout wrong in that previous image, though it doesnt make much difference. The correct image is below.
Moonfly is offline
post #100 of 241 Old 12-20-12, 12:38 PM Thread Starter
Mike P.'s Avatar
Mike
BL should be 14.01 N/A, that will clear things up.
Mike P. is offline
downloadable , files , pro , winisd
