Small vented vs large vented Winisd question - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 3 Old 09-07-19, 01:21 PM Thread Starter
I currently have a 12 cubic foot vented enclosure and now I am switching to two 4.5 cubic foot vented end table subs on each side of the couch. While modeling in Winisd, I am showing the same output and response curve (within one db)if I add an 8db boost at 20hz to the smaller box. I tweaked the input and ended up with half the power needed to get the smaller box to the xmax. I find it hard to believe that a vented enclosure of one third the size is more efficient. I am using the Dayton Classic 15". I'm not sure if I am doing something wrong or if adding EQ throws off Winisd power calculations in some way. I am not at home now, but I will post screenshots of my inputs. Has anyone else run into odd power estimates in this software?
clint357 is offline
post #2 of 3 Old 09-11-19, 07:34 PM
BP1Fanatic's Avatar
Re: Small vented vs large vented Winisd question
I use Hornresp to model enclosures.
Basshead 4 Life
Sony XBR65X900E
Sony STR-DN1080
Sony PS4
Quantum Access Fanless Mini PC Stick
Wow! Ultra Cable
8 x Rockville SPG88 DJ PA Speakers
Dayton Audio SA1000 Sub Amp
Kicker 08S15L74 sub in a T-TQWT (negative flare tapped horn)
BP1Fanatic is offline
post #3 of 3 Old 09-11-19, 07:38 PM Thread Starter
I have attached some screenshots showing eq settings, input power, excursion, and box parameters. I have the boxes designed in CAD and I really want to cut them this weekend, but I want to make sure that my numbers jive. Any advice is appreciated. I will play with hornsrep tonight to see how that works compared to winisd.
clint357 is offline
large , question , small , vented , winisd
