what driver would be best - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 5 Old 02-15-10, 01:15 PM Thread Starter
New Member
stdgrabbag
hi, im am new here and new to speaker building in general. my problem is, is that i currently have a 3.5 cu ft box along with an oaudio 500watt plate. what im unsure of is what sub would be best for this box. what i would mostly be using it for is movie watching. so basically what would be a good choice for a driver, a 15 or a 12? my choices are for the 15 is dayton titanic mkIII, or the Tempest-X2. for my 12 choices would be the Shiva-X2, or the titanic again in a 12. if my box is to big should i consider porting? thanks
octagon is offline
post #2 of 5 Old 02-15-10, 01:36 PM
dyohn's Avatar
David
Re: what driver would be best
A Tempest sealed in 3.5 cuft would be an excellent choice. Wire it for 4-ohms with your amp and you'll be cooking with gas...
dyohn is offline
post #3 of 5 Old 02-15-10, 01:54 PM Thread Starter
New Member
stdgrabbag
i was really leaning towards that, what kind of results would i have?
octagon is offline
post #4 of 5 Old 02-15-10, 01:59 PM
dyohn's Avatar
David
Take a look at Kevin's application notes. He modeled it in 3 cuft, your performance would be similar.
http://www.diycable.com/main/pdf/TX2Apps.pdf
dyohn is offline
post #5 of 5 Old 02-15-10, 02:22 PM
Mike P.'s Avatar
Mike
dyohn wrote: View Post
Agreed. You can use the 16 hz HPF with the boost, the amp will clip before you run out of excursion.
We're all in this together!
Mike P. is offline
driver
