Driver with unknown T/S parameters.... - Page 3 - Home Theater Forum and Systems - HomeTheaterShack.com
post #21 of 33 Old 03-25-10, 06:52 PM Thread Starter
favelle
Re: Driver with unknown T/S parameters....
Mike P. wrote: View Post
The driver doesn't determine the tuning frequency, the box volume and port surface area and length do.
Oh, cool. Good to know. So without knowing the driver T/S, I could still design an 80L enclosure that is tuned to 22-24hz with either a 3" port or a 4" port. Can I use WinISD for this?
favelle is offline
post #22 of 33 Old 03-25-10, 07:04 PM Thread Starter
favelle
In WinISD, I got a 90L enclosure with TWO 3" ports @ 22" long = a tuning of 22hz. Does that sound right? I am going to make 2 endcaps. One with a 22hz tuning and one with a longer port (15") for a 24hz tuning and see which one sounds better in the real world.
Am I seeing the numbers correctly?
favelle is offline
post #23 of 33 Old 03-25-10, 08:10 PM Thread Starter
favelle
Remeasured the original cabinet and port. Inside dimensions of the cabinet is 14 x 14 x 10" (~1900 in^3). The port is a slot-pot design and its 12 inches long, 5 inches wide and 1.75 inches tall.
favelle is offline
post #24 of 33 Old 03-26-10, 01:29 AM
Mike P.'s Avatar
Mike
That means it's a 1 cu.ft. box tuned to 40 hz. Now we can guesstimate the amp has a hi-pass filter around 40 hz or so. If you put the sub in a bigger cabinet there's no sense tuning any lower since the amp is blocking the frequencies below 40 hz. If you do put the sub in a bigger box and tune it to 40 hz, the sub will bottom out since it takes less power to reach Xmax in a bigger cabinet. This should tell you the sub, amp, cabinet size and tuning were all designed to work together for this specific application. I strongly suggest you put the sub and amp back in the original cabinet. If you do decide to pursue this let us know how it turns out.
We're all in this together!
Mike P. is offline
post #25 of 33 Old 03-26-10, 01:44 AM Thread Starter
favelle
I think I am still going to try it. At the very worst, it will suck and I can just swap out the endcap for one that fits an SDX10 or something.
Should be able to start cutting this weekend!
favelle is offline
post #26 of 33 Old 03-26-10, 12:28 PM Thread Starter
favelle
Just wondering if my numbers are correct. If I have an 80L enclosure (4882 in^3) and I wanted a 24hz tune with a 3" PVC pipe, that pipe would be 15" long, right? Just want to make sure befor I cut...
favelle is offline
post #27 of 33 Old 03-26-10, 09:08 PM Thread Starter
favelle
Hoping these cabinet calculations are right?
One more question; if the amp indeed has an active high-pass filter, can I play test tones from 60hz down to 20hz or whatever in 1-2hz increments and determine the high-pass cutoff when there ceases to be a sound played?
favelle is offline
post #28 of 33 Old 03-26-10, 09:47 PM
Mike P.'s Avatar
Mike
I'm at work, I'll check your calculation when I get a chance. The filter isn't a brick wall, the SPL will drop so many db's per octave depending on what "order" the filter is. A second order filter will drop 6 db per octave, a third will drop 9 db's, a forth will drop 12 db's.
Mike P. is offline
post #29 of 33 Old 03-26-10, 09:52 PM Thread Starter
favelle
Can EQ then defeat a HP filter by boosting the lower frequencies? Obviously nobody with that kind of equalizer would be running a budget build like this, but I was just curious.
Thanks Mike! I start cutting tomorrow. Right now its an 80L build with a 21" ong 4" PVC port!
favelle is offline
post #30 of 33 Old 03-26-10, 10:22 PM
Mike P.'s Avatar
Mike
You can only boost if you have the power and the sub has the excursion capabilities. A 6 db boost takes 4 times the amount of power. If you send 150 watts to a sub and a frequency is boosted 6 db, that frequency would require 600 watts.
Mike P. is offline
driver , parameters.... , unknown
