what 15 inch driver - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 20 Old 05-14-10, 02:54 AM Thread Starter
Eccentric
Re: what 15 inch driver
How about in a sealed box 130 litres?
Jason Schultz is offline
post #12 of 20 Old 05-14-10, 02:55 AM Thread Starter
Eccentric
Do you think I could do with more power in a medium sized room for the 20-30 hz stuff
post #13 of 20 Old 05-14-10, 08:03 AM
Mike P.'s Avatar
Mike
What size sealed or ported was the Shiva in?
We're all in this together!
Mike P. is offline
post #14 of 20 Old 05-15-10, 01:47 AM Thread Starter
Eccentric
Mike it is in a 120L box ported to 20HZ. maybe box has developed a leak but i can't see how. I know that the dynamic range and deep bass content on blue ray discs is extreme But i've never used up x- max before so easily! Ithink its time to upgrade anyhow.
post #15 of 20 Old 05-15-10, 07:19 AM
Mike P.'s Avatar
Mike
White is what you have, yellow and pink are the Tempest-X and the IXL-18, both in 130 liters sealed with 750 watts of power.
and both subs ported in 130 liters with 1000 watts and the appropriate hi-pass filter.
Mike P. is offline
post #16 of 20 Old 05-16-10, 04:56 AM Thread Starter
Eccentric
Thanks for modelling those for me. I can see i will have to get more proficient at entering driver specs into winisd. I think the sealed version of tempest is still attractive since it needs no high pass filter at 18 Hz. Room gain would see output into the teens too I reckon. If I go ported i would have drama trying to get a six inch diam port into a 130L box, in which case i would be looking at an 18" passive Radiator,$$$$ !. In any case "more power scotty " will be the answer. I Also think my shiva has been on the recieving end of sub 20Hz signals pushing it above x max. I might experiment with test tones to see if it is guilty of exceeding it's legel limit of x-max with say 16 HZ signals. Mike do you have info (graph) on driver excursion for shiva in my aformentioned box using say a 500W input ? please. If it doesn't exceed x-max I will have to search elsewhere for cause of clacking sound.
Also which driver , Tempest x2 or IXL18 would have better sound quality playing at moderate levels?
post #17 of 20 Old 05-16-10, 06:24 AM
Jason Schultz wrote: View Post
See attachments:130L sealed, 500W
My gut says the T15 because of the motor design.
Lucky7! is offline
post #18 of 20 Old 05-16-10, 06:41 AM
FWIW here are the T15 and IXL18 compared. Both are 130L sealed 500W applied. FR comparo and excursion for each.
Lucky7! is offline
post #19 of 20 Old 05-16-10, 06:16 PM Thread Starter
Eccentric
thanks A9x. I was leaning towards the tempest ( motor design )and it looks as though it will be within x-max too with 500 watts. I was shocked to see The shive3 graph for cone excursion. It definately doesn't have anywhere near the cone excursion I need for 105dB at 20 HZ. Thanks mate. Now I am armed with enough info to start new sub design !
post #20 of 20 Old 05-16-10, 06:29 PM
The Shiva is quite an old design now. If you have a spare amp and EQ, corner loaded might produce enough output to be a worthwhile addition and the help even out some room modes. The models are 1/2 space (sub in middle of parking lot) and show no room gain. Something to think about later maybe.
Bill's Boxnotes software is worth downloading and having a play with to help with the final details of the design. And of course you can ask here.
I'd also so a search and read all the Tempest build threads and as many as you can absorb of other builds as you'll pick up a ton of small constructional details that will help with the design and build.
When you start building, a build thread with pics is a must.
Lucky7! is offline
driver , inch
