DIY Speaker and Subwoofer Project Tools and Tips - Page 4 - Home Theater Forum and Systems - HomeTheaterShack.com
post #31 of 37 Old 03-15-10, 03:06 AM
Be Mo
Re: DIY Speaker and Subwoofer Project Tools
My favorite and, IMO, the most versatile tool I own is my router. I see that lots of routers have been posted, so I can see I am not alone.
I have owned many brands of routers, and most of them have served me well.
But my Hitachi KM12VC combo fixed/plunge is the one I use the most. I have always been a purist. But this hitachi has the best balance to weight to power ratio I have found.
I also believe router bits are a place you shouldn't skimp.
Get the best quality for your budget at least in the most frequently used sizes and shapes in speaker/cab making.
Second up... I just couldn't live without my 17" Grizzly band saw. I have a 3 1/2" slab of dark walnut I will be cutting in to veneers leaving enough for 1" baffles on my R/c/L speaker project. I am also considering a curved cabinet design. In witch case the band saw will be my workhorse.
Be_Mo_Mods is offline
post #32 of 37 Old 09-18-10, 04:50 AM
alaok's Avatar
Re: DIY Speaker and Subwoofer Project Tools and Tips
As broad-based tools for an earnest diyer, making enclosure will concern with a lot of things: design tools, woodworking tools...... And I think, some accoustics measurement tools are needed also, use them to tune the enclosure.
alaok is offline
post #33 of 37 Old 11-16-10, 07:40 AM
KKOO
Which tool should I buy for rounding the edges?
kkoo is offline
post #34 of 37 Old 11-16-10, 08:32 AM
tcarcio's Avatar
TC
You can buy a round over bit for your router. If you don't have a router you can rent one if you don't want to buy one.
tcarcio is offline
post #35 of 37 Old 01-09-12, 11:01 AM
caper26's Avatar
Oscillating Spindle Sander:
caper26 is offline
post #36 of 37 Old 08-28-12, 11:38 AM
Tim
Re: DIY Speaker and Subwoofer Enclosure Tools
Sonnie wrote: View Post
This is the router I ordered based on recommendations here at the Shack...
Bosch 1617EVSPK 2.25 Horsepower Electronic Variable Speed Plunge and Fixed Base Router Kit
Price: $179.00 shipped from COP Bosch (Reconditioned)
Beautiful router!
loach71 is offline
post #37 of 37 Old 10-10-13, 05:12 PM
colofan's Avatar
colofan
I don't have a picture of it but i made a birch plywood jig to guide. 3 foot by 4 foot and 5 foot Diag. I can then trim plywood sheets square before using the table saw or anything else. Sheet goods a typically not square. MDF is better than plywood but not spot on.
colofan is offline
diy , project , speaker , subwoofer , tips , tools
