[help] sub driver recommend - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 52 Old 06-30-10, 12:31 AM
Mike P.'s Avatar
Mike
Re: [help] sub driver recommend
If you mean outperform I would say yes.
Each PR's will need 550 grams of mass added to tune the box to 21 hz.
We're all in this together!
Mike P. is offline
post #12 of 52 Old 06-30-10, 01:06 AM Thread Starter
Mike P. wrote: View Post
thank you for reply
I can not wait to buy .
but I do not know how to choice impedance
a9155040 is offline
post #13 of 52 Old 06-30-10, 01:31 AM
Mike P.'s Avatar
Mike
You want the dual 2 ohm subs, each sub is wired in series for a 4 ohm load, one sub connects to each channel of the amp.
Mike P. is offline
post #14 of 52 Old 06-30-10, 02:24 AM Thread Starter
you mean AV15-H is DVC? like that
http://www.hometheatershack.com/images/1xSeries_DVC.jpg
a9155040 is offline
post #15 of 52 Old 06-30-10, 02:43 AM
Mike P.'s Avatar
Mike
Yes.
Mike P. is offline
post #16 of 52 Old 06-30-10, 03:34 AM Thread Starter
thanks for replay
this design's net volume is 6.2 cu.ft?
http://www.hometheatershack.com/foru...6.2&l1=175.564
above connect,I do not see the brace you show me.
how to calculate brace volume of your design?
a9155040 is offline
post #17 of 52 Old 06-30-10, 04:14 AM
Mike P.'s Avatar
Mike
The link won''t show your calculations, you'll have to post a screen shot.
Here is the cut sheet for the 24" cube design. This was originally for a SDX15 sub, your cutout diameters will have to be for the A.E. sub and Exodus PR's.
Mike P. is offline
post #18 of 52 Old 06-30-10, 05:25 PM
Marce
Shackster, also consider the AE AV15X driver. In a box of 6.5-7.0cf with PR's, it might be a better option than the AV15H driver which does very well in smaller enclosures. The H driver is a bit better for the low bass and the X model a bit better for the mid-bass. I'm using the X model in a 7cf box with 18" PR's and it has impressive performance. I also believe this sub with either the X or H driver in a 6-7cf PR box with some 1,000watts of power behind it will beat the Ultra 13 with no problem for the mid-bass (50hz-100hz). The low bass performance (below 30hz or so) should be very close between the two.
spanish68 is offline
post #19 of 52 Old 07-01-10, 08:37 PM Thread Starter
hello~
I have bought 1 AV15-H and 2 PRs
Do I need foam and cotton?
have any suggest?
a9155040 is offline
post #20 of 52 Old 07-01-10, 08:47 PM
Mike P.'s Avatar
Mike
Probably not. Build the sub and see how it sounds first.
Mike P. is offline
driver , recommend , [help]
