[help] sub driver recommend - Page 4 - Home Theater Forum and Systems - HomeTheaterShack.com
post #31 of 52 Old 01-05-12, 01:26 PM
hamtor
Re: [help] sub driver recommend
Passive Radiator EX-PR18
SPECIFICATIONS
Fs: 20 Hz
Qms: 6.8
Mms: 300g
Cms: 0.20 mm/N
Vas: 391L
Sd: 1182 cm^2
Excursion: 32-35mm one-way
hamtor is offline
post #32 of 52 Old 01-05-12, 06:43 PM Thread Starter
I send e-mail to ask them. but I do not get any reply.
so I measure diameter of the PR-15 by myself
a9155040 is offline
post #33 of 52 Old 01-06-12, 06:05 AM
Mike P.'s Avatar
Mike
I found the parameters that I need for the 15 inch Passive Radiators. What make and model number of amplifier are you using to power your sub?
We're all in this together!
Mike P. is offline
post #34 of 52 Old 01-06-12, 06:10 AM Thread Starter
I buy behringer EP4000. Many people suggest it.
a9155040 is offline
post #35 of 52 Old 01-06-12, 06:24 AM
Mike P.'s Avatar
Mike
Do you have a hi-pass filter for the amp?
Mike P. is offline
post #36 of 52 Old 01-06-12, 08:28 AM Thread Starter
I do not have hi-pass filter.
I connect sub to yamaha RX-V765. I will buy a DSP named anti-mode 8033
a9155040 is offline
post #37 of 52 Old 01-06-12, 08:48 AM
Mike P.'s Avatar
Mike
The Anti-Mode 8033 is an equalizer, it does not provide a hi-pass filter. You need a hi-pass filter to protect your driver and PR's from bottoming out.
Here are the different weights for your PR's.
Green- 550 grams added to each PR, 21 hz tuning, HPF at 18 hz.
Purple- 700 grams added to each PR, 19 hz tuning, HPF at 17 hz
Yellow- 850 grams added to each PR, 18 hz tuning, HPF at 16 hz
Orange- 1000 grams added to each PR, 17 hz tuning, HPF at 16 hz
Mike P. is offline
post #38 of 52 Old 01-06-12, 08:56 AM
Mike P.'s Avatar
Mike
The red line is the Xmax limit of the driver, without a HPF the driver will bottom out.
The same applies to the PR's.
Mike P. is offline
post #39 of 52 Old 01-06-12, 07:13 PM Thread Starter
I am very grateful to you so much. you help me a lot.
ok, I will consider to buy a product that provide a hi-pass filter.
would you suggest good, cheap high-pass filter for me?
a9155040 is offline
post #40 of 52 Old 01-07-12, 03:25 AM Thread Starter
I read some article on the web.
Many people suggest Reckhorn B2, elmental design EQ.2 ,behringer mic2200 or Diy ( but I do not know how to design...)
behringer mic2200:I know I can buy it on the parts express
elmental design EQ.2: I can buy it one elmental design website
but I do not know where I can buy Reckhorn B2
or other good HPF?
a9155040 is offline
driver , recommend , [help]
