bass cabs - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 36 Old 01-20-07, 01:42 AM Thread Starter
drf
drf
bass cabs
I am thinking of building a bass cab, just wondering what allignments people curently use and what particular sonics they attribute to specific allignments, I am not overly concerned about the particulars of what each size driver should be capable of, but more what peoples impressions are.
For example I was thinking of a single 15" cab with a 2x 12" cab ontop, the idea being low end and a certain amount of projection in the one stack. Maybe even some piezo tweeters to compliment the 2x12"'s ?
cheers
dr f
drf is offline
post #2 of 36 Old 01-20-07, 05:14 AM
Bryan Nemecek
Inactive
Posts: n/a
Re: bass cabs
drf wrote: View Post
cheers
dr f
Are you are building the speaker box, or buying a box to put a speaker into? Will the box be ported?
Is this bass speaker intended for 'sub' duty?
What will the sound duty of the 2x12's be, to produce 'full range' sound?
You mentioned tweeters, will this system be actively or passively crossed-over?
You may want to post your question over in the "DIY Speakers and Subwoofers" area.
B-DoGG
post #3 of 36 Old 01-20-07, 11:24 AM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
Re: bass cabs
drf,
Is this for PA use? The reason I ask is that your driver compliment seems peculiar. Usually PA’s use 18” horn-loaded subs, 15” woofs for the mids, and compression drivers for the highs.
post #4 of 36 Old 01-20-07, 04:51 PM Thread Starter
drf
drf
Re: bass cabs
sorry, I meant bass guitar cabinets. I am currently designing a head amp. But I wanted some opinions on the different qualities each particular setup has:
E.g
do 4x10" cabs generally have a crisp sound? and or does a single 15" generally have a boomy quality?
I realise a lot of tone is dependent on many things like driver quality, application and environmental accoustics, however I am just after general feeling or impressions as I haven't had the opportunity to compare varying setups.
My idea with the 2x12"s was a single cabinet with some tweeters to get the higher freq's.
I haven't thought about crossovers because I usually decide/design those to suit whatever driver arrangement I have settled on.
edit: just learning how to use google sketchup, this is something along the lines I was thinking but haven't done any mathes and is not to scale:
drf is offline
post #5 of 36 Old 01-20-07, 08:17 PM
Dan
Send a message via MSN to Danny
Re: bass cabs
Question - if it is a bass guitar cab why are you putting tweeters in it? IMO they are unneeded.
Danny is offline
post #6 of 36 Old 01-20-07, 09:20 PM Thread Starter
drf
drf
Re: bass cabs
IIRC Bass guitar has harmonics upto 2khz, with some snap and edge definition above this (5 to 7Khz is not unheard of). The average 12" driver can breakup at 2Khz. This, to me, seems to leave some of the defining characteristics of the instrument to the mercy of a larger drivers high end ability. So I figure a tweeter or 2 could relieve the drivers of this burden.
drf is offline
post #7 of 36 Old 01-21-07, 01:03 AM
Re: bass cabs
I believe large full range drivers are available aren't they? I'm thinking those who do the Open Baffle type systems.... they use full range 15" drivers. Could you use those okay?
Sonnie is offline
post #8 of 36 Old 01-21-07, 03:25 PM
Re: bass cabs
Danny wrote: View Post
Not to mention, the highs from large-diameter drivers is very directional and “beamy.” So everything sounds very different to listeners who are in front of the cabinet, vs. listeners who aren’t.
I never could fully get behind the 4-10 arrangement, always seemed to lack in the lowest frequencies.
Interestingly, there is a migration in bass cabinets these days towards 12” drivers, as a “best of both worlds” between the 10s and 15s. I played on a little Aguilar 1-12 w/ tweeter several months ago, and it’s arguably the best sounding cabinet I’ve ever heard. Great extension, even with a 5-string, and very smooth and linear from the low notes to the high, no “boominess” or one-note quality. I want one!
If I was going to do a custom rig like yours, I’d do it like they do with home speakers, not like they typically do with bass cabinets. With bass systems, they typically have the big driver running full range and handing off the upper frequencies to the smaller drivers. What I’d do is run the small drivers as low as they’d play, then hand off the lower frequencies to the large driver. Naturally, this will require bi-amping with a good electronic crossover.
I’d also pass on peizo tweeters, as those things are pretty cheap and nasty-sounding, IMO. I’d go for a good-quality horn-loaded compression driver, like they use in PA systems. Makes perfect sense, especially if you’re going to be patched into a PA system anyway: what you here on-stage will be a better match for what your audience will hear of you from the system.
Another thought, if you’re going to be patched into a PA system with subs, you can dispense with the 15” altogether and let the system carry the bottom end for you. After all, what’s the point of trying to make a 15-incher compete with a pair of horn-loaded 18” subs??
You might want to bounce your question off the guys at the Talkbass Forum. Lots of good, informed advice there.
post #9 of 36 Old 01-21-07, 11:42 PM Thread Starter
drf
drf
Re: bass cabs
Thanks, I have no problems with bi-amping, to be Honest I much prefer active crossovers/biamping to passive.
That sounds like a good idea, I could set out the amp to have a selectable crossover so a 15" cab can be added at a future date. Only problem with that is I didn't really want to build three poweramps for the one head, just two. I suppose I could have a pre out that is low passed, then just add a third amp when using the 15.
I could use those, but even the best built 15" drivers will suffer cone breakup after 1-2Khz. In some cases they barely make it to 1Khz before breakup can be measured/heard.
drf is offline
post #10 of 36 Old 01-22-07, 11:22 AM
Re: bass cabs
I wonder how the likes of Hawthorne Audio get their OB (open baffle) systems with full range drivers to sound good... and they use those for home theater and two channel. They actually have some pretty good reviews too. I think we have someone who is writing up something on their OB's and it may give us some insight. It just got me thinking that they must have better full range drivers available somewhere.
Sonnie is offline
bass , cabs
