Very low budget sub. - Page 4 - Home Theater Forum and Systems - HomeTheaterShack.com
post #31 of 54 Old 02-01-07, 01:50 PM
BoomieMCT's Avatar
Boom
Re: Very low budget sub.
No prob. diysubwoofers.org is "da bomb".
BoomieMCT is offline
post #32 of 54 Old 02-01-07, 02:49 PM Thread Starter
Mike
See my edit, I keep on getting some insanely large numbers.
mgboy is offline
post #33 of 54 Old 02-01-07, 02:59 PM
BoomieMCT's Avatar
Boom
mgboy wrote: View Post
I don't know. To be honest, I always just use Unibox and let the computer crunch the numbers. Without seeing your work the only thing I can suggest is that you double check that all your units match up (esp. for the density of air).
post #34 of 54 Old 02-01-07, 03:10 PM Thread Starter
Mike
Well, I did it for just one PR (instead of two) and came up with 1307 grams, which is like 2.88 lbs. That has to be way too much, I mean, they sample driver they used was like 280 grams, which is less than a pound.
Can it support ~ 3 lbs on the bolt? < Dumb question. I know it can, but it still seems like a lot.
mgboy is offline
post #35 of 54 Old 02-01-07, 03:22 PM
BoomieMCT's Avatar
Boom
Well, according to the spec sheet the stock mass is 200 grams and the maximum moving mass is 500 grams (total, I assume). So, if the tune you are trying for requires 1307 grams then you may need three PR's, buy a 15" Dayton DVC PR or a TC-Sounds PR or change the tune of the sub.
But first let me double check my math - I'll get back to you in a few hours (since I have to wait to go home first).
BTW, what tune were you using?
post #36 of 54 Old 02-01-07, 03:27 PM Thread Starter
Mike
22Hz. >_> I really want it, but I may just stick iwth a port if I'm going to have to get multiple PR's.
mgboy is offline
post #37 of 54 Old 02-01-07, 03:35 PM
BoomieMCT's Avatar
Boom
If you really want to keep this "very low budget" I saw somewhere that someone had made their own PR's from speaker surrounds and MDF. Apparantly it worked pretty well down to 20 Hz or so (when it started flapping).
post #38 of 54 Old 02-01-07, 03:37 PM Thread Starter
Mike
lol, No that's okay. But that's pretty ingenius.
mgboy is offline
post #39 of 54 Old 02-01-07, 04:12 PM
BoomieMCT's Avatar
Boom
Okay, here is a first stab at this. First off, I made the input power 200 watts as that is the most RMS power the driver's voice coil can take (don't max out your amp). I used 170 liters (6 cubic feet) as the size of the enclosure. Here is a plot of the EHQS-12 driver with two of the cheaper Dayton 12" PR's. One has no additional mass (which results in a 30 Hz F3), the other has 300 grams extra weight on each PR (the most it can take). That one is tuned too low and results in an F3 of 43 Hz.
As a note (not included), the low mass one barely exceeds driver excursion on the active driver at 25 Hz, but the PR exceeds it at 30 Hz. The high mass one had all kinds of excursion problems starting at 50 Hz.
post #40 of 54 Old 02-01-07, 04:26 PM
BoomieMCT's Avatar
Boom
Here is what I mean. Some of these excursion problems go away by using a smaller box and/or adding a third PR. I haven't yet gotten the driver to not overexcurse below 25Hz no matter what I do (for PR or ported).
I'd almost be tempted to experiment with a sealed box with an aperiodic vent.
budget , low
