$700 budget ported Sub + Amp - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 17 Old 10-24-11, 06:32 AM Thread Starter
TagUrToast
Re: $700 budget ported Sub + Amp
If I used a 21" cube with 3/4" wood, should I still bother with internal bracing? Also I have heard that the fan is noisy, the room which it will be in is also used as a study area while quiet music/radio is on (playing through this system) so I would like to get it as quiet as possible. Has anyone attempted making the heatsink bigger and passive? or used very quiet fans with it?
TagUrToast is offline
post #12 of 17 Old 10-24-11, 09:15 AM
Adam
Always Brace internally, Especially for a 15" driver with 30mm one way xmax. Doubling up the thickness of the mounting baffle is usually recommended as well.
The Behringer EP is a solid performer, Fan mods are common, But as far as power/dollar goes, the Behringers are near-impossible to beat.
The Fun part here is that if you've got extra power, and a small-ish sealed box, you can use something like the MiniDSP to get extra extension, at the cost of head room of course. I Currently own an SDX15 in a large low tuned cabinet. I love it. 14 cubes internal @ 15hz.
Binary is offline
post #13 of 17 Old 10-25-11, 05:13 AM Thread Starter
TagUrToast
Binary, would you happen to have any pics of your sub?
post #14 of 17 Old 10-25-11, 07:41 AM
Adam
http://www.hometheatershack.com/foru...-complete.html
The build was completed, but I never bothered to put any kind of finish on the box.
Binary is offline
post #15 of 17 Old 10-26-11, 11:17 AM
RodK's Avatar
Here is a link to my sub build using an SDX 15 in a sealed box, except I used a plate amp.
http://www.hometheatershack.com/foru...plate-amp.html
It sounds amazing. I am very happy with it.
RodK is offline
post #16 of 17 Old 11-01-11, 08:04 PM Thread Starter
TagUrToast
So I am going to use it in a 4 Cu. Ft box, should i be considering some kind of foam/padding inside the box?
post #17 of 17 Old 11-02-11, 09:25 AM
Adam
You're doing a sealed build?
If so, yes, stuff it. It will help in two ways, it'll trick the box into thinking it's bigger, and it'll absorb any of the upper bass that remains after crossover. (18DB/octave leaves quite a bit of content above 80)
Binary is offline
$700 budget 12 , ported
