what type of speaker - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 19 Old 12-12-12, 06:20 PM Thread Starter
epic 12
I am thinking 3 epic 12s would need a bigger cabinet.. correct?
striperri is offline
post #12 of 19 Old 12-12-12, 11:49 PM
Mike P.'s Avatar
Mike
Re: what type of speaker
Not by much, 4.5 cu.ft. is a Q of .7. 4 cu.ft. is a Q of .73.
We're all in this together!
Mike P. is offline
post #13 of 19 Old 12-13-12, 05:44 PM Thread Starter
SO you think I could go for it mike. Sorry the number dont mean alot to me. I am totally novice about it.
post #14 of 19 Old 12-14-12, 12:14 AM
Mike P.'s Avatar
Mike
I was just looking at the wiring possibilities. Since they are D2 ohm drivers the wiring options are 1.34 ohm, 3 ohm, or a 12 ohm load. An amp that can supply 1500 watts or more at 2 ohms should work for a 3 ohm load from the drivers.
Mike P. is offline
post #15 of 19 Old 12-14-12, 08:02 AM
Zeitgeist's Avatar
Jim
paskal wrote: View Post
you're probably better off designing the sub with horizontal brace rather than vertical brace like that. the 3 large panel without any bracing have a possibility they'll vibrate with low frequency. if it were me, i'd put at least 2 vertical brace to support all the panels simultaneously.
it'd be far easier to cut them even.
I agree with the bracing concern. I think that it does need some horizontal bracing.
Zeitgeist is offline
post #16 of 19 Old 12-15-12, 02:32 PM Thread Starter
think i will order the epics. will start thread when building starts
post #17 of 19 Old 12-28-12, 06:53 PM Thread Starter
Mike P
got one of teh 3 lms-r's in today The graph you did earlier can you tell me how low the hz will go on that.
thnaks in advance
post #18 of 19 Old 12-29-12, 01:06 AM
Mike P.'s Avatar
Mike
The graph goes down to 10 hz but how loud it will be will depend on how much room gain you get.
Mike P. is offline
post #19 of 19 Old 12-29-12, 01:15 AM
gperkins
Gosh I remember that design. The bracing on that is fine. The drivers located where they are will probably cancel out any vibrations any way.
It will be good to see that come to life as it took ages to design and work out.
Watching this!!!!
gperkins_1973 is offline
speaker , type
