Monaural out to line level (L/R) inputs - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 5 Old 09-08-13, 01:25 AM Thread Starter
New Member
Just got a new 7.2 receiver and am hooking it up to an older Polk subwoofer. The receiver has 2 subwoofer RCA outputs (monaural) and the subwoofer has a left and right RCA line input (it also has speaker level inputs/outputs but I don't want to use these). Can I use just one RCA cable to either of the left or right RCA inputs on the subwoofer? Or do I need to run 2 cables-- one from each of the subwoofer outs on the receiver to left and right inputs on the subwoofer. Or do I need an RCA Y adapter single male to double male? Thanks for any guidance.
bmeighan is offline
post #2 of 5 Old 09-08-13, 01:14 PM
bobbeyo's Avatar
On a sub I had in the past with a plate amp built in you would run the mono sub out to the right input on the sub amp (leaving the left channel empty). I don't know if this is how yours works, otherwise just use a splitter. Bob
bobbeyo is offline
post #3 of 5 Old 09-08-13, 01:15 PM
Kal
Re: Monaural out to line level (L/R) inputs
bmeighan wrote: View Post
It will work either way. Using both outputs may give you a higher output that can facilitate the auto-sensing on/off switching, if your sub has such.
Kal Rubinson
__________________________________
"Music in the Round"
Senior Contributing Editor, Stereophile
Kal Rubinson is online now
post #4 of 5 Old 09-08-13, 01:19 PM
HTS Senior Moderator
fusseli's Avatar
You don't need to use both inputs to the sub and if neither of the L/R inputs have an LFE marking you can use either one.
fusseli is offline
post #5 of 5 Old 09-08-13, 09:20 PM Thread Starter
New Member
Thanks for the guidance. It's working as expected.
bmeighan is offline
cabling , inputs , l or r , level , line , monaural , subwoofer , wiring
